null image number 0
null image number 1
null image number 2
null image number 3
null image number 4
null image number 5
null image number 6
null image number 7
null image number 8
null image number 9
null
null
null
null
null
null
null
null
null
null
FULL MODULAR 80 PLUS GOLD ATX POWER SUPPLY UNIT
MWE Gold 750 - V2 (Full Modular)
MWE Gold - V2 (Full Modular) is the next step in the evolution of Cooler Master's entry level 80 PLUS Gold power offerings.
Model
立即購買
2 EPS Connectors
Quiet Cooling
The MWE Gold - V2 has been upgraded with an HDB fan. This fan bearing delivers quiet and effective cooling with a long lifespan, allowing users to get the most out of their PSU for years to come. A number of additional measures have been applied to the original MWE Gold in order to reduce sound output and ripple noise for a demonstrably quieter user experience.
High Temperature Resilience
While the original MWE Gold had a maximum operating temperature of only 45 degrees Celsius, the MWE Gold - V2 has improved upon this by delivering an additional 5 degrees to that limit. With this model, users will be able to push their power supply to 50 degrees Celsius safely. Such a high threshold greatly improves what's possible to accomplish with your PSU and your system in general. Overclocking and other high intensity applications become way more accessible when the system's power supply can take the heat.
80 Plus Gold Certified
  • ���號 MPE-7501-AFAAG
  • ATX 版本 ATX 12V Ver. 2.41
  • 功率因數校正 主動式 PFC
  • 輸入電壓 100-240V
  • 輸入電流 10-5A
  • 輸入頻率 50-60Hz
  • 尺寸 (長 x 寬 x 高) 160 x 150 x 86 mm
  • 風扇尺寸 120mm
  • 風扇軸承 HDB
  • 風扇轉速 1500 RPM
  • 噪音水平 @ 20% 0 dBA
  • 噪音水平 @ 50% 17.8 dBA
  • 噪音水平 @ 100% 24.9 dBA
  • 轉換效率 典型轉換 90%
  • 80 PLUS 評級 80 PLUS 金牌
  • ErP 2014 Lot 3 符合
  • 工作溫度 0-50°C
  • 電源良好信號 100 - 150 ms
  • 持續輸出時間 >16ms at 100% Load
  • 平均故障間隔 (MTBF) >100,000 小時
  • 保護機制 UVP / OVP / OPP / OTP / SCP / OCP
  • 安規 TUV, CE, CCC, EAC, RCM, cTUVus, FCC, BSMI, UKCA
  • ATX 24 Pin 電源接頭 1
  • EPS 4+4 Pin 電源接頭 1
  • EPS 8 Pin 電源接頭 1
  • SATA 電源接頭 12
  • 周邊 4 Pin 電源接頭 4
  • PCI-e 6+2 Pin 電源接頭 4
  • 產品系列 MWE Gold 系列
  • 分類 500-750瓦
  • 模組化 全模組化
  • 80 Plus 金牌認證
  • Watts 750W
