Power Evolved
MWE Bronze 650 V3
ATX 3.1 support
High temperature resilience
Quiet HDB fan
80 Plus Bronze certified efficiency
Embossed cable
5-year warranty
Power Evolved
Cooler Master presents the MWE Bronze V3, the upgraded version of the MWE Bronze featuring ATX 3.1 support, high temperature resilience, a smart DC-to-DC + LLC circuit design, a quiet HDB fan, 80 Plus Bronze efficiency, an embossed cable, and a 5-year warranty.
ATX 3.1 Support
Compliant with ATX 3.1 to fully support a peak power 1.5 times higher than the rated maximum wattage, this unit is ideal for use with the 40 series GPUs.
Embossed Cable
Quiet HDB Fan
Certified Efficiency
The MWE Bronze V3 is certified to achieve more than 85% efficiency at typical loads.​​
High Temperature Resilience
PSU Calculator
@ Cooler Master Technology Inc. (VAT: 54272387)
