MWE Bronze 550 V3 230V image number 0
MWE Bronze 550 V3 230V image number 1
MWE Bronze 550 V3 230V image number 2
MWE Bronze 550 V3 230V image number 3
MWE Bronze 550 V3 230V image number 4
MWE Bronze 550 V3 230V image number 5
MWE Bronze 550 V3 230V image number 6
MWE Bronze 550 V3 230V image number 7
Power Evolved
ATX 3.1 support
High temperature resilience
Quiet HDB fan
80 Plus Bronze certified efficiency
Embossed cable
5-year warranty
ATX 3.1 Support
Compliant with ATX 3.1 to fully support a peak power 1.5 times higher than the rated maximum wattage, this unit is ideal for use with the 40 series GPUs.
Embossed Cable
Quiet HDB Fan
Certified Efficiency
The MWE Bronze V3 230V is certified to achieve more than 88% efficiency at typical loads.​​​​
High Temperature Resilience
  • 型號 MPE-5501-ACABW-3B
  • ATX 版本 ATX 12V Ver. 3.1
  • 功率因數校正 主動式 PFC
  • 輸入電壓 200-240V
  • 輸入電流 5A
  • 輸入頻率 50-60Hz
  • 風扇尺寸 120mm
  • 風扇軸承 HDB
  • 轉換效率 >88% @ Typical Load
  • 80 PLUS 評級 80 PLUS 銅牌 EU 230V
  • ErP 2014 Lot 3 符合
  • 工作溫度 0-40°C
  • 電源良好信號 100 - 150 ms
  • 持續輸出時間 >16ms
  • 平均故障間隔 (MTBF) >100,000 小時
  • 保護機制 UVP / OVP / OPP / OTP / SCP
  • 安規 TUV, CE, FCC, CCC, EAC, RCM, UKCA, RoHS2.0 / BIS, KC (based on region's request.)
  • ATX 24 Pin 電源接頭 1
  • SATA 電源接頭 6
  • 周邊 4 Pin 電源接頭 3
  • PCI-e 6+2 Pin 電源接頭 2
  • 保固 5 Years
  • 產品系列 MWE Bronze 系列
  • 分類 500-750瓦
  • 模組化 無模組化
  • 80 Plus 銅牌認證
  • Watts 550W
