MWE 650 Bronze - V2 銅牌 650W 電源供應器 image number 0
MWE 650 Bronze - V2 銅牌 650W 電源供應器 image number 1
MWE 650 Bronze - V2 銅牌 650W 電源供應器 image number 2
MWE 650 Bronze - V2 銅牌 650W 電源供應器 image number 3
MWE 650 Bronze - V2 銅牌 650W 電源供應器 image number 4
MWE 650 Bronze - V2 銅牌 650W 電源供應器 image number 5
MWE 650 Bronze - V2 銅牌 650W 電源供應器 image number 6
MWE 650 Bronze - V2 銅牌 650W 電源供應器 image number 7
MWE 650 Bronze - V2 銅牌 650W 電源供應器 image number 8
80 PLUS 銅牌認證電源供應器
MWE Bronze 通過 80 Plus 銅牌認證,能確保典型負載轉換效率平均達 85%,DC-DC 搭配 LLC 電路設計讓設備能可靠、安全、有效率的由 12V 單路供電取得需要的電源,提供更好的整體使用體驗。電源供應器在待機或是低負載作業時能以靜音模式運作。
DC-to-DC Circuit Design
80 PLUS Bronze Efficiency
The efficiency of your power supply unit is important because it directly affects you system’s performance and your power bill. The efficiency rating does not reflect the quality or reliability of a PSU. It only reflects the unit’s ability to move power from the wall to your components. The higher a PSU’s efficiency is, the lower the total amount of power it needs to power your system. The MWE Bronze series has an 80 PLUS Bronze efficiency rating, meaning it has a guaranteed typical efficiency of 85%.
Active Power Factor Correction
The many processes required by a power supply unit in order to take power directly from the wall or other fixed power source, convert it to the correct output required by the connected components, and then distribute that power to said components safely can be full of risks. This is why it’s important for a PSU to have the right protections and regulations to ensure this process runs correctly.
The MWE Bronze’s Active Power Factor Correction uses a specialized circuit to correct power factor, leading to reduced total harmonics, corrected AC input voltage, and increased overall efficiency output.
120mm HDB Fan
  • 型號 MPE-6501-ACAAB-TW
  • ATX 版本 ATX 12V V2.52
  • 功率因數校正 主動式 PFC
  • 輸入電壓 100-240V
  • 輸入電流 10-5A
  • 輸入頻率 50-60Hz
  • 風扇尺寸 120mm
  • 風扇軸承 HDB
  • 風扇轉速 2400 RPM
  • 噪音水平 @ 20% 11.06 dBA
  • 噪音水平 @ 50% 22.3 dBA
  • 噪音水平 @ 100% 41.3 dBA
  • 轉換效率 典型轉換 85%
  • 80 PLUS 評級 80 PLUS 銅牌
  • ErP 2014 Lot 3 符合
  • 工作溫度 40°C
  • 電源良好信號 100 - 500 ms
  • 持續輸出時間 >18ms (100% 負載) 230Vac
  • 平均故障間隔 (MTBF) >100,000 小時
  • 保護機制 UVP / OVP / OPP / OTP / SCP
  • 安規 CCC, CE, TUV-RH, RCM, EAC, cTUVus, FCC, BSMI, KC, CB
  • ATX 24 Pin 電源接頭 1
  • EPS 4+4 Pin 電源接頭 1
  • EPS 8 Pin 電源接頭 1
  • SATA 電源接頭 8
  • 周邊 4 Pin 電源接頭 4
  • PCI-e 6+2 Pin 電源接頭 4
  • 產品系列 MWE Bronze 系列
  • 分類 500-750瓦
  • 模組化 無模組化
  • 80 Plus 銅牌認證
  • Watts 650W
