Motion 1 Haptic Gaming Chair image number 0
Motion 1 Haptic Gaming Chair image number 1
Motion 1 Haptic Gaming Chair image number 2
Motion 1 Haptic Gaming Chair image number 3
Motion 1 Haptic Gaming Chair image number 4
Motion 1 Haptic Gaming Chair image number 5
Motion 1 Haptic Gaming Chair image number 6
Motion 1 Haptic Gaming Chair image number 7
Motion 1 Haptic Gaming Chair image number 8
Motion 1 Haptic Gaming Chair image number 9
Motion 1 Haptic Gaming Chair image number 10
Motion 1 Haptic Gaming Chair image number 11
Motion 1 Haptic Gaming Chair image number 12
COMFORT / IMMERSION / REVOLUTION
Motion 1, the world's first haptic engine gaming chair.
立即購買
D-BOX CODED GAMING
The Tech That Powers Life-like Immersion. Discover why the D-BOX Coded Gaming experience is at the cutting edge of immersive technology. Brace yourself for the heart-pounding tension and exhilarating release of the Hunter's Bow as it gracefully expands and contracts in your hands. Feel the raw power of the crashing waves as they collide with your boat during daring raids. With Motion 1, Assassin's Creed Valhalla becomes an extraordinary journey, immersing you in a realm of unparalleled life-like immersion that was once deemed impossible.
D-BOX CODED VIDEO
Rewatch and experience your favorite movies like never before,
with D-BOX Coded Video on your Motion 1.
Feel the world around you disappear.
D-BOX Catalogue
2500+
GAMES AND MOVIES
Safety
Ergonomic comfort
Safety
Motion 1 has been tested to provide a safe and enjoyable haptic experience, passing multiple durability tests with up to 120 kg of weight. The custom Cast Aluminum wheelbase delivers a solid and sturdy base for years to come. For improved safety and the highest haptic settings, Motion 1 has lockable casters that provide enhanced stability and secure positioning.
Adjustments
Ergonomic comfort
Adjustments
Motion 1 features an extensive range of adjustments to achieve the ideal 90-degree angle from your knees to the ground. Crafted from 3D sculpted foam, Motion 1 has gone through rigorous testing by our designers and engineers. Every curve and contour is perfected to ensure optimal comfort, pressure distribution, and endurance during your immersive haptic sessions. Additionally, relax with Motion 1's 120 degrees of reclining, providing the perfect rest during your well- deserved breaks. The magnetic headrest and lumbar pillows add another layer of luxury and comfort, easily adjustable in height and effortlessly removable while adjustable armrests provide optimal positioning.
  • 產品型號 CMI-GCMT1-BK-110
  • 顏色 黑色
  • 整體高度範圍 122-127 cm
  • 椅背高度 87 cm
  • 靠背寬度 57.5 cm
  • 扶手到扶手寬度 71 cm
  • 座椅寬度 (含側邊) 58.4 cm
  • 可坐範圍 48 cm
  • 座椅深度 53.5 cm
  • 本體直徑 80 cm
  • 扶手可調範圍 23.5-27.5 cm
  • 地板至椅墊高度 45.5-50.5 cm
  • 可調後仰角度 90-120 度
  • 高度可調範圍 5 cm
  • 扶手 Adjustable (up and down)
  • 頭枕 Magnetic ergo pillow
  • 腰部支援 Magnetic ergo lumbar support
  • 外部用料 Eco-friendly fabric (Non-toxic polyester) on front and PU leather
  • 內部用料 冷成型泡綿
  • 框體材質 Plywood and injected plastic
  • 底座材質 (腳) 鋁合金
  • D-box haptic system Yes
  • 輸入電壓 Two verions: 1. 120V, 50/60 Hz, 2A , 2. 230V, 50/60 Hz, 1.1A (NOT switchable)
  • PC Connection USB 2.0 or higher
  • 電源線相容性 US, UK, EU, AU
  • 軟體 MasterPlus+
  • 相容性 Win 7, 8, 10, 11
  • 最大負重 120 kg
  • 產品保固 2 年
  • 產品分類 電競椅
  • 電競椅系列 Motion 系列
