Mobius 120 機殼風扇 image number 0
Mobius 120 機殼風扇 image number 1
Mobius 120 機殼風扇
Mobius 120 機殼風扇
極致效能,絕佳平衡
Mobius 120 機殼風扇
Cooler Master 推出Mobius系列效能風扇,Mobius 120
 PERFECTING ENGINEERING
Cooler Master’s Mobius 120 is our new series of performance fans. With our enhanced Ring Blade Design, the Mobius Series optimizes both performance and acoustics, catering to a dynamic range of applications from case, liquid or air, to overclocking and intense gaming.
OIL REFLOW
DUST PROOFING
ANTI-SWAY SYSTEM
Pressure Acceleration Air Vents
Angled inner frame rim with chamfered side vents boost airflow draw, The structural ring blade eliminates any fan deformation- Ring Blade keeps the fan build structure rigid, inflexible, stiff and rigor
45 deg Q in and Q out, larger air flow in and air flow out increasing the Q
  • 產品型號 MFZ-M2NN-21NPK-R1
  • 外觀顏色 黑色
  • 風扇設定檔 無 LED
  • 風扇轉速 0-2050 RPM ± 10%
  • 風扇風量 63.1 CFM
  • 風扇噪音水平 22.6 dBA
  • 風扇軸承類型 循環動態軸承 (Loop Dynamic Bearing, LDB)
  • 風扇風壓 2.69 mmH2O
  • 風扇平均故障間隔 >200,000 小時
  • 風扇連接介面 4-Pin (PWM)
  • 風扇額定電壓 12 VDC
  • 風扇額定電流 0.12A
  • 風扇安全電流 0.35A
  • 風扇功耗 1.44W
  • 風扇重量 179g
  • 產品保固 5年
  • 產品類型 機殼風扇
  • 系列 Mobius 系列
  • 風扇LED種類 Non-LED
