MM712 Wired 電競滑鼠 image number 0
MM712 Wired 電競滑鼠 image number 1
MM712 Wired 電競滑鼠 image number 2
MM712 Wired 電競滑鼠 image number 3
MM712 Wired 電競滑鼠 image number 4
MM712 Wired 電競滑鼠 image number 5
MM712 Wired 電競滑鼠
MM712 Wired 電競滑鼠
MM712 Wired 電競滑鼠
MM712 Wired 電競滑鼠
MM712 Wired 電競滑鼠
MM712 Wired 電競滑鼠
回歸精湛技藝
MM712 Wired 電競滑鼠
感受MM712 Wired的強大魅力,這是Cooler Master廣受好評的MM710系列的有線版本輕量化遊戲滑鼠的第三代。它擁有Pro版本中所有令人印象深刻的功能:PAW3395光學感測器,鐵氟龍(PTFE)滑鼠腳提供無與倫比的滑動性,光學微動開關可實現極快的輸入速度
The 49 Gram Legacy – Our Lightest Mouse Yet
What truly sets the MM712 apart is its class-leading weight. Engineered with a cleverly structured chassis and a superlight frame weighing just 49 grams, this mouse feels like an extension of your hand, effortlessly gliding across your gaming surface. Say goodbye to fatigue during intense gaming marathons—the MM712’s ergonomic design ensures comfort and control through every high-stakes battle and extensive work session.
Center Stage
Center Stage
With feedback from our community of gamers, the MM712 now positions the sensor dead center of its mass, ensuring perfectly balanced weight distribution and a consistent feel during lifts and swipes.
Zero Pull, Frictionless Glide from Superior PTFE Feet
Redesigned curved-edge PTFE feet make the MM712 glide effortlessly across any surface with zero cable pull.
Cooler Master Exclusive Ultraweave Cable
Exceptionally lightweight and designed for tighter control, Ultraweave eliminates cable snag and reduces drag for quicker and smoother swipes in the heat of the battle.
The Masterkey with On-Board Safe-Keeping
The new MasterPlus+ software from Cooler Master unlocks the MM712’s full potential. Adjust your settings, remap buttons, set up macros and profiles, and more. Once configured, all your settings are stored directly on the device, providing a true plug-and-play experience with a set-it-and-forget-it convenience.
* The software only supports Windows 7 and above.
Learn More
Set Your Style, Your Team Colors, Your Mood
Personalize your mouse in style with 16.7M customizable illuminating RGB colors. Sync colors across all your Cooler Master devices or adjust RGB effects in real time via key combos or MasterPlus+ Software.
Wheel + Forward = Change LED color
Wheel + Backward = Cycle LED modes
  • 產品型號 MM-712-KKOL1
  • 滑鼠握法 Claw, Palm, Fingertip
  • 滑鼠材質 ABS 塑膠
  • 鼠腳 PTFE
  • 滑鼠顏色 黑色
  • 滑鼠LED 有 , 於LOGO上的RGB
  • 滑鼠感應器 PixArt PWM3395
  • CPI/DPI 靈敏度 400-800-1200(預設)-1600-3200-8000-26000
  • 滑鼠追蹤速度 650 ips
  • 滑鼠工作高度 < ~2mm
  • 滑鼠回報速率 1000Hz
  • 角度修正 支援
  • 滑鼠加速 50g
  • 內建記憶體 512KB
  • 左右鍵微動壽命 Optical Switches, 70 Million
  • 滑鼠鍵數 6
  • 軟體支援 有, Cooler Master MasterPlus+ 支援
  • 滑鼠線材長度 Ultraweave 編織線材, 1.8m
  • 滑鼠尺寸 116.5 x 62.4 x 38.3 mm / 4.587 x 2.457 x 1.508 inches (L x W x H)
  • 滑鼠重量 < 50g
  • 保固 2 年
  • 產品 滑鼠
