Legendary Gaming Mouse – Fast, Precise, and Superlight
Step into the realm of legends with the MM712 Wired Gaming Mouse. Dominate the game, seize victory, and leave your mark as an unstoppable force in the gaming universe. Elevate your gameplay and your mastery. The MM712 is reborn with an improved shape, enhanced accessibility, precision, and weight. Whether it’s repetitive work clicks or fast, accurate shots, the MM712 delivers pixel-perfect accuracy, empowering you to execute flawless maneuvers with pinpoint precision.
The 49 Gram Legacy – Our Lightest Mouse Yet
What truly sets the MM712 apart is its class-leading weight. Engineered with a cleverly structured chassis and a superlight frame weighing just 49 grams, this mouse feels like an extension of your hand, effortlessly gliding across your gaming surface. Say goodbye to fatigue during intense gaming marathons—the MM712’s ergonomic design ensures comfort and control through every high-stakes battle and extensive work session.
Elite Gaming-Grade Optical Sensor
The MM712 is equipped with a state-of-the-art PAW3395 optical sensor, offering up to 26,000 DPI resolution, 50G acceleration, and 650 IPS max speed. This powerful combination makes it an explosive weapon in any arena.
Hit It with the Speed of Light
The MM712 is fitted with two optical micro switches for instant fire and an extended lifetime. Laser sensors do not require the same debounce delay commonly found in traditional switches and register inputs nearly three times faster for almost zero input latency during your game.
Center Stage
With feedback from our community of gamers, the MM712 now positions the sensor dead center of its mass, ensuring perfectly balanced weight distribution and a consistent feel during lifts and swipes.
Zero Pull, Frictionless Glide from Superior PTFE Feet
Redesigned curved-edge PTFE feet make the MM712 glide effortlessly across any surface with zero cable pull.
You asked, and we listened! The MM712 features a completely new body and redesigned key contours, including a pronounced finger rest for improved grip and a rising edge chamfer for added comfort for your ring finger.
The MM712 now features an improved side-button design with chamfered edges to reduce chafing and a wider gap for better accessibility.
Cooler Master Exclusive Ultraweave Cable
Exceptionally lightweight and designed for tighter control, Ultraweave eliminates cable snag and reduces drag for quicker and smoother swipes in the heat of the battle.
The Masterkey with On-Board Safe-Keeping
The new MasterPlus+ software from Cooler Master unlocks the MM712’s full potential. Adjust your settings, remap buttons, set up macros and profiles, and more. Once configured, all your settings are stored directly on the device, providing a true plug-and-play experience with a set-it-and-forget-it convenience.
* The software only supports Windows 7 and above.
Set Your Style, Your Team Colors, Your Mood
Personalize your mouse in style with 16.7M customizable illuminating RGB colors. Sync colors across all your Cooler Master devices or adjust RGB effects in real time via key combos or MasterPlus+ Software.
Wheel + Forward = Change LED color
Wheel + Backward = Cycle LED modes
@ Cooler Master Technology Inc. (VAT: 54272387)
