MM712 30th Anniversary Edition Gaming Mouse image number 0
MM712 30th Anniversary Edition Gaming Mouse image number 1
MM712 30th Anniversary Edition Gaming Mouse image number 2
MM712 30th Anniversary Edition Gaming Mouse image number 3
MM712 30th Anniversary Edition Gaming Mouse image number 4
MM712 30th Anniversary Edition Gaming Mouse image number 5
MM712 30th Anniversary Edition Gaming Mouse image number 6
Lightweight Prestige
The MM712 is the next evolution of our first popular lightweight mouse, leveled up to lightweight prestige.
  • 產品型號 MM-712-KCOH1
  • 滑鼠握法 Palm / Claw
  • 滑鼠材質 ABS Plastic / Rubber / PTFE
  • 滑鼠 LED 顏色 16.7 Million RGB
  • 滑鼠感應器 PixArt Optical Sensor
  • CPI/DPI 靈敏度 400-800-1200(Default)-1600-3200-8000-19000
  • 滑鼠追蹤速度 400 ips
  • 滑鼠工作高度 < ~2mm / Adjustable
  • 滑鼠回報速率 2.4GHz/Wired Mode: 1000 Hz, BT Mode: 125 Hz
  • 角度修正 Yes
  • 滑鼠加速 50g
  • 左右鍵微動壽命 Optical Switches, 70 Million
  • 滑鼠鍵數 6
  • 連接方式 Wired / 2.4GHz / Bluetooth 5.1
  • 電池 500 mAh
  • 電池壽命 Bluetooth Mode: 180hrs (with LED Off), 2.4GHz Mode: 80hrs (with LED Off)
  • 充電方式 Support Wired charging
  • 作業系統 Windows 8+ / macOS / Andriod / iOS
  • 軟體支援 Yes, Cooler Master MasterPlus+ Support
  • 滑鼠線材 Detachable Ultraweave Cable, 1.8 M (Type-C to Type-A) with Gold-plated
  • 尺寸 (長 x 寬 x 高) 116.5 x 62.4 x 38.3 mm / 4.6 x 2.5 x 1.5 inch
  • 滑鼠重量 < 58g / 0.13 lbs (w/o Dongle & Cable)
  • 保固 2 years
  • 產品 Mice
