MM310 SF6 Chun-Li Gaming Mouse image number 0
MM310 SF6 Chun-Li Gaming Mouse image number 1
MM310 SF6 Chun-Li Gaming Mouse image number 2
MM310 SF6 Chun-Li Gaming Mouse image number 3
MM310 SF6 Chun-Li Gaming Mouse image number 4
MM310 SF6 Chun-Li Gaming Mouse image number 5
The MM310 is a wired gaming mouse buffed with an innovative new feature set focused on performance This includes pro grade 12 000 DPI optical sensor
Special Edition
Cooler Master
x Capcom Street Fighter 6
The MM310 wired gaming mouse, with its exclusive
color scheme and design, weaves together the aesthetics
of Street Fighter 6 and Cooler Master's gaming expertise,
embodying the spirit of Chun-Li.
Design
Lightweight Ambidextrous Design
Optimized for right-handers with two side buttons and weighs in at 50g without exterior holes that compromise on aesthetics.
 Customizable Features
MasterPlus+ Support
New, improved software allows you to remap controls, customize your RGBs, tune your macros, and more.
Cable
Ultraweave Cable
Super lightweight and engineered in-house to prevent cable snag when swiping.
Illumination
RGB Lighting
Give your victories some flashy good looks
with lighting on the logo and the scroll wheel.
Adjustability
Gaming Grade Sensor
Adapt to your game or playstyle with optical sensor
adjustable up to 12,000 DPI.
Performance
Upgraded Mouse Feet
New-and-improved feet made with PTFE material for low friction and high durability, which provides a smooth, fast glide with maximum responsiveness.
  • 產品型號 MM-310-WWOL2
  • 滑鼠握法 Palm / Claw
  • 滑鼠材質 ABS Plastic / Rubber / PTFE
  • 滑鼠顏色 快打旋風六 - 春麗聯名設計
  • 滑鼠 LED 顏色 1670萬 RGB
  • 滑鼠感應器 PixArt 光學傳感器
  • CPI/DPI 靈敏度 400-800-1,200(預設)-1600-3200-6200-12000
  • 滑鼠追蹤速度 220 ips
  • 滑鼠工作高度 N/A
  • 滑鼠回報速率 125 / 250 / 500 / 1000 MHz (透過軟體切換)
  • 角度修正 支援
  • 滑鼠加速 30g
  • 左右鍵微動壽命 Mechanical Micro Switch, 60M
  • 滑鼠鍵數 6
  • 連接方式 有線
  • 作業系統 Windows8+ / macOS
  • 軟體支援 有, Cooler Master MasterPlus+ 支援
  • 滑鼠線材 Ultraweave Cable, 1.8 M (Type-C to Type-A) with Gold-plated
  • 滑鼠尺寸 125.5 x 71.0 x 40.5 mm
  • 滑鼠重量 50g (不含線材)
  • 產品 滑鼠
