MK721 30th Anniversary Edition Gaming Keyboard image number 0
MK721 30th Anniversary Edition Gaming Keyboard image number 1
MK721 30th Anniversary Edition Gaming Keyboard image number 2
MK721 30th Anniversary Edition Gaming Keyboard image number 3
MK721 30th Anniversary Edition Gaming Keyboard image number 4
MK721 30th Anniversary Edition Gaming Keyboard image number 5
MK721 30th Anniversary Edition Gaming Keyboard image number 6
MK721 30th Anniversary Edition Gaming Keyboard image number 7
Your Everyday PC Carry
The MK721 wireless mechanical keyboard redefines the daily driver, striking the perfect balance between form and function for both work and play.
  • 鍵盤類型 Mechanical
  • 產品 Keyboard
  • 保固 2 years
  • 鍵盤材質 Plastic
  • 充電方式 Support Wired charging
  • Keyboard Extra Keycap Set PBT Double Shot
  • Keyboard Extra Keycap Set OEM Profile
  • 反應時間 1ms (Wired/2.4GHz Mode)
  • 電池壽命 73hrs (LED Off)
  • 反應時間 8ms (Bluetooth Mode)
  • 連接方式 Wired
  • 連接方式 2.4 GHz
  • 鍵盤材質 Aluminum
  • 鍵盤回報速率 125Hz (Bluetooth Mode)
  • 作業系統 Windows 8+
  • 電池 2000mAh
  • 作業系統 Mac OS X 10.10+
  • 連接方式 Bluetooth 5.1
  • 鍵盤回報速率 1000Hz (Wired/2.4GHz Mode)
  • 作業系統 Android
  • 軟體支援 Cooler Master MasterPlus+
  • 手托 Cloth/SBR, 334 x 95 x 18 mm
  • 鍵盤 LED 顏色 RGB, 16.7 million colors
  • 作業系統 iOS
  • 鍵盤線材 USB Type C to Type A
  • 鍵盤線材 1.6m
  • 鍵盤鍵帽 OEM Profile
  • 動態操控系統 Yes, via FN
  • 鍵盤線材 Detachable & Coiled Braided
  • 鍵盤鍵帽 PBT Double-Shot
  • 鍵盤尺寸 (長 x 寬 x 高) Standard: 334 x 118 x 37 mm / 13.15 x 4.65 x 1.46 inches
  • 鍵盤尺寸 (長 x 寬 x 高) With 1st stage feet open: 334 x 118 x 43 mm / 13.15 x 4.65 x 1.69 inches
  • 鍵盤尺寸 (長 x 寬 x 高) With 2nd stage feet open: 334 x 118 x 46 mm / 13.15 x 4.65 x 1.81 inches
  • 鍵盤重量 764g / 1.68 lbs (without Cable & Dongle)
  • 鍵盤軸體種類 Kailh Box V2 Mechanical Switch (Red/White/Brown)
  • 產品型號 MK-721-CKTR1/L1/M1-US
