MasterLiquid PL240 TR5-SP6 image number 0
MasterLiquid PL240 TR5-SP6 image number 1
Optimized for AMD Threadrippers
Large, full-coverage copper base
Mobius 120 fans
All-in-one thermal solution
Ultimate Cooling for Extreme Performance
Cooler Master’s high-performance MasterLiquid series is back with the MasterLiquid PL240 TR5-SP6 Edition, a new cooler specifically designed for optimal performance with AMD Threadripper CPUs. Packing our state-of-the-art Mobius 120 fans and an all-in-one design, this latest addition to the MasterLiquid line of products gives you everything you need to buff your machine with a powerful blast of cooling energy. Synergize your AMD build with the MasterLiquid PL240 TR5-SP6.
This edition of the MasterLiquid series has been specially designed for AMD TR5-SP6 CPUs only
The extensive copper base spreads heat more evenly across the cooling surface, allowing for quicker dissipation and maintaining lower CPU temperatures even under heavy loads.
Mobius 120 fans
Our critically acclaimed Mobius 120 fans provide both high-end thermal performance and unparalleled noise control
Pre-applied thermal paste and easy snap-on brackets make installation and set-up a breeze
  • 產品名稱 MasterLiquid PL240 TR5-SP6
  • 產品型號 MLO-R24M-A24PK-RA
  • 外觀顏色 黑色
  • CPU 腳位 AMD® TR5/SP6
  • 水冷排尺寸 277 x 119.2 x 27.2 mm(10.9 x 4.7 x 1.1 inch)
  • 水冷排材質
  • 幫浦尺寸 117.9 x 78.9 x 24.5 mm(4.6 x 3.1 x 1 inch)
  • 幫浦使用壽命 > 70,000 hours
  • 幫浦噪音等級 30 dB(A)
  • 幫浦轉速 3000 RPM ± 10%
  • 幫浦連接器 4-Pin
  • 幫浦額定電壓 12 VDC
  • 幫浦功耗 8.16 W
  • 風扇尺寸 (長 x 寬 x 高) 120 x 120 x 25 mm ​ (4.7 x 4.7 x 1 inch)
  • 風扇數量 2 個
  • 風扇 LED 類型 Non-LED
  • 風扇轉速 0~2400 ±10%
  • 風扇風量 127.6m³/h (75.2 CFM)
  • 風扇噪音水平 30 dBA (最大)
  • 風扇壓力 3.63 mmH₂O (最大)
  • 風扇軸承類型 循環動態軸承 (Loop Dynamic Bearing, LDB)
  • 風扇平均故障間隔 >200,000 小時
  • 風扇連接介面 4-Pin (PWM)
  • 風扇額定電壓 12 VDC
  • 風扇額定電流 0.18A
  • 風扇安全電流 0.35 A
  • 水冷排尺寸 240
  • 產品類型 CPU水冷散熱器
  • 系列 MasterLiquid
