Global Headquarters
Intel® Cryo 散熱技術讓酷碼 MasterLiquid ML360 Sub-Zero 水冷散熱器提供超越一般等級的體驗。完美利用矽材質的特性,讓電腦能夠在單核或雙核的超頻環境中,以較低的電壓達到較高的CPU頻率,並得以在低於室溫的情況下同時保持系統運行的穩定性。
Newly Designed Pump traditionally used in DIY cooling systems with high performance motor that has an enhanced repeller to dissipated heat from the TEC in a more efficiently.
Sub-Ambient Cooling
Specifically designed using Thermoelectric Unit (TEC) to cool your processor and create the conditions that allow it to achieve low core count over-clocking.
Powered by Intel Cryo Cooling Technology
Designed with a simple user interface making it easy to understand and control the sub-ambient cooling potential.
Cryo-Clocking
Silicon can reach higher frequencies at lower voltages that can only be achieved through sub-ambient cooling. The concept of Cryo-Clocking is to push
2nd Generation Pump
Enhanced pump delivers higher liquid flow for exceptional heat removal.
A: Top Mounted 360 mm Radiator
B: Front Mounted Pump
To get the best performance for your system for you CPU we recommend a top installation of the 360mm radiator and a front installation of the pump. The fans are pre-installed on the radiator and pump bracket pre-attached (out-of-box).
Overclocking your CPU doesn’t have to be complicated and can be achieved in 2 basic ways:
Overclocking through BIOS Settings
OR
Using Intel XTU Software
