MasterLiquid ATMOS Stealth Series image number 0
MasterLiquid ATMOS Stealth Series image number 1
MasterLiquid ATMOS Stealth Series image number 2
MasterLiquid ATMOS Stealth Series image number 3
360 Degrees of Cool
Exceptional silence
Optimized user experience
Fully customizable
Eco-friendly construction
Refined dual chamber design
The pump cover is manufactured from eco friendly recycled plastics
and features a transparent, removable top cover that allows you to
customize it with your own logo or badge. This version of the ATMOS is also an all blackout, non LED release, allowing for a super stealthy
aesthetic. Cooler Master is leaping into the future with the ATMOS
series.
Design
Fully customizable
Customize the pump top cover with your 3D designs and take full control of the ARGB Gen 2 lighting. The Atmos provides unprecented creative freedom.
Cooling System
DUAL CHAMBER DESIGN
DUAL CHAMBER DESIGN
Patented design
DUAL CHAMBER DESIGN
Improved Quality
Gadget
TUBE CLIPS INCLUDED
Tube clips are made for AIO tube size that not only to improve and strengthen your cooler setup,but also can fix your ARGB or PWM cables.
Gadget
THERMAL PASTE
APPLICATION STICKER
Materials
The pump top cover has been constructed from recycled plastic materials, while 35% of the cooler's metal materials are recycable. Along with sustainable packaging materials and a 30% reduction in total packaging size, the Atmos is an eco-pioneer.
Fans
MOBIUS 120 BLACK FANS
Pre-installed Mobius 120mm black fans further improve cooling performance and simplify user installation.
Our Achievements
8 awards
  • 產品型號 MLX-D36M-A24PK-R1 (MasterLiquid 360 ATMOS Stealth)
  • 產品型號 MLX-D24M-A24PK-R1 (MasterLiquid 240 ATMOS Stealth)
  • 外觀顏色 黑色
  • CPU 腳位 Intel® LGA 1851 / 1700 / 1200 / 1156 / 1155 / 1151 / 1150 Socket
  • CPU 腳位 AMD® AM5 / AM4 Socket
  • 水冷排材質 鋁
  • 水冷排尺寸 394 x 119.2 x 27.2 mm / 15.5 x 4.7 x 1.1 inch (MasterLiquid 360 ATMOS Stealth)
  • 水冷排尺寸 277 x 119.2 x 27.2 mm​ / 10.9 x 4.7 x 1.1 inch (MasterLiquid 240 ATMOS Stealth)
  • 幫浦尺寸 84.9 x 81 x 53.15 mm 3.3 x 3.2 x 2.1 inch
  • 幫浦使用壽命 >210,000 小時
  • 幫浦噪音等級 25 dBA (最大)
  • 幫浦轉速 3400 ± 300 RPM
  • 連接介面 4-Pin
  • 幫浦額定電壓 12 VDC
  • 幫浦功耗 3.84 W
  • 風扇尺寸 (長 x 寬 x 高) 120 x 120 x 27 mm
  • 風扇數量 3 個
  • 風扇數量 3 個
  • 風扇轉速 0-2400 RPM ± 10%
  • 工作溫度 127.6 m³/h (75.2 CFM)
  • 風扇噪音水平 30 dBA
  • 風扇壓力 3.63 mmH₂O (最大)
  • 風扇軸承類型 循環動態軸承 (Loop Dynamic Bearing, LDB)
  • 風扇平均故障間隔 >200,000 小時
  • 風扇連接介面 4-Pin (PWM)
  • 風扇額定電壓 12 VDC
  • 風扇額定電流 120mm 風扇: 0.18 A
  • 安全電流 0.35A
  • 風扇功耗 2.16 W
  • 產品保固 5年
  • 產品類型 CPU水冷散熱器
  • 系列 MasterLiquid
