MasterFan MF120 Halo² 3in1 機殼風扇 image number 0
MasterFan MF120 Halo² 3in1 機殼風扇 image number 1
MasterFan MF120 Halo² 3in1 機殼風扇 image number 2
MasterFan MF120 Halo² 3in1 機殼風扇 image number 3
MasterFan MF120 Halo² 3in1 機殼風扇 image number 4
MasterFan MF120 Halo² 3in1 機殼風扇 image number 5
雙環世界
MasterFan 120 Halo系列廣受市場歡迎後不久,Cooler Master推出了重新設計的雙光環系列風扇,名為MasterFan MF120 Halo²。MF120 具有 10% 更大的風扇葉片以提高空氣流動和散熱性能。框架採用混合結構設計保持穩定性而不犧牲空間。
A DUAL NEW WORLD
A DUAL NEW WORLD
The MasterFan MF120 Halo² is our redesigned dual loop LED series fan, now available as a 3-in-1 pack, giving you triple the cooling power. The MF120 features 10% larger fan blades for improved air flow and cooling performance. The frame has been designed with a hybrid structure that maintains stability without sacrificing operational real estate. An upgraded driver IC is also included for increased cooling performance and minimal fan noise, while the elegant dual loop LED design is maintained via addressable gen 2 RGB lighting that provides the ultimate customizable experience. Enter a dual new world with the the MasterFan MF120 Halo².
HYBRID FRAME DESIGN
A hybrid frame structure maintains stability without sacrificing fan blade size or performance.
LED CONTROLLER
UPGRADED DRIVER IC
An upgraded driver IC boosts cooling performance while minimizing fan noise.
  • 產品型號 MFL-B2DN-213P2-R2
  • 外觀顏色 黑色
  • 設定檔 Addressable Gen 2 RGB
  • 風扇轉速 0-2050 RPM ± 5%
  • 風扇風量 51.88 CFM
  • 風扇噪音水平 27 dBA
  • 風扇軸承類型 來福軸承 (Rifle Bearing)
  • 風扇壓力 2.89 mmH₂O
  • 風扇平均故障間隔 >160,000 小時
  • 風扇連接介面 4-Pin (PWM)
  • 風扇額定電壓 12 VDC
  • 風扇額定電流 0.14A
  • 風扇安全電流 0.37A
  • 風扇功耗 1.68W
  • RGB 連接介面 3-Pin ARGB
  • RGB 額定電壓 5 VDC
  • RGB 額定電流 0.77A
  • 風扇重量 174g
  • 產品保固 2年
  • 產品類型 機殼風扇
  • 系列 MasterFan
  • 風扇尺寸 120
  • 風扇LED種類 ARGB
