MasterCase Pro 3 LED Partition Plate image number 0
MasterCase Pro 3 LED Partition Plate image number 1
MasterCase Pro 3 LED Partition Plate image number 2
MasterCase Pro 3 LED Partition Plate image number 3
MasterCase Pro 3 LED Partition Plate image number 4
MasterCase Pro 3 LED Partition Plate image number 5
Make of It What You Will!
  • 支援 Replacement for MasterCase Pro 3 Partition Plate
  • 開關 Sata cable connection
  • 配件 LED Accessory
  • Legacy Accessories
  • 淨重 0.37 Kg
  • 系列 Others
  • 材質 Steel frame, 4mm thick transparent acrylic panel
  • 顏色 Transparent when off; Choose between blue LED, red LED, and white LED
  • 尺寸 (長x寬x高) 390 x 198 x 11 mm
  • 產品型號 MCA-C300R-WLPP00 (White LED)
  • 產品型號 MCA-C300R-RLPP00 (Red LED)
  • 產品型號 MCA-C300R-BLPP00 (Blue LED)
