MasterBox TD500 Mesh V2 中直立式機殼 image number 0
MasterBox TD500 Mesh V2 中直立式機殼 image number 1
MasterBox TD500 Mesh V2 中直立式機殼 image number 2
MasterBox TD500 Mesh V2 中直立式機殼 image number 3
MasterBox TD500 Mesh V2 中直立式機殼 image number 4
MasterBox TD500 Mesh V2 中直立式機殼 image number 5
MasterBox TD500 Mesh V2 中直立式機殼 image number 6
MasterBox TD500 Mesh V2 中直立式機殼 image number 7
MasterBox TD500 Mesh V2 中直立式機殼 image number 8
MasterBox TD500 Mesh V2 中直立式機殼 image number 9
MasterBox TD500 Mesh V2 中直立式機殼 image number 10
MasterBox TD500 Mesh V2 中直立式機殼 image number 11
MasterBox TD500 Mesh V2 中直立式機殼 image number 12
MasterBox TD500 Mesh V2 中直立式機殼 image number 13
MasterBox TD500 Mesh V2 中直立式機殼 image number 14
MasterBox TD500 Mesh V2 中直立式機殼 image number 15
MasterBox TD500 Mesh V2 中直立式機殼 image number 16
MasterBox TD500 Mesh V2 中直立式機殼 image number 17
MasterBox TD500 Mesh V2 中直立式機殼 image number 18
MasterBox TD500 Mesh V2 中直立式機殼 image number 19
精緻至極
MasterBox TD500 Mesh V2 - Cooler Master ATX電腦機箱,多邊形網孔面板,內建四顆ARGB風扇。
顏色
立即購買
Design
FINEMESH PERFORMANCE FRONT PANEL
Polygonal FineMesh features a 3D contour and is also capable of simultaneously providing high airflow and dust filtration.
Colors
AVAILABLE IN BOTH BLACK & WHITE
Our Achievements
7 AWARDS
Fans
THREE CF120 ARGB FANS INCLUDED
Pre-installed CF120 ARGB fans provide ample airflow, ensuring low temperatures, high performance, and eye-catching aesthetics during even the most intense gaming sessions.
USB 3.2 GEN 2 Type C Support
Ports & Slots
USB 3.2 Gen 2 Type C port built into the 1/0 panel allows multi-purpose, streamlined data transmission.
REMOVABLE TOP PANEL
The top panel is entirely removable for improved access during assembly and ease of mounting of cooling solutions.
Motherboard
Hardware Compatibility
MasterBox TD500Mesh V2 is natively compatible with ITX, M-ATX and ATX motherboards.
E-ATX motherboards, such as SSI-CEB models, are compatible with dimensions up to 12" x 10.7".
Customization
VERSATILE COOLING OPTIONS
Support for up to seven 120mm fans and 60mm front and top radiator support nsure that performance is not ompromised.
TOOL-FREE CRYSTALLINE TG SIDE PANEL
Featuring a crystalline tempered glass side panel, completely toolless for quick access to the internals.
PSU SHROUD WITH REMOVABLE COVER
MasterBox TD500 Mesh V2's removable PSU cover allows users to freely decide whether to showcase or keep their PSUs hidden.
  • 產品型號 TD500 Mesh V2: TD500V2-KGNN-S00, TD500 Mesh V2 White: TD500V2-WGNN-S00
  • 外觀顏色 黑色, 白色
  • 材質 - 外部 Steel, Mesh, Plastic
  • 材質 - 左側板 鋼化玻璃
  • 尺寸 (長x寬x高) 499 x 210 x 500mm (包含突出部位), 430 x 210 x 477mm (不包含突出部位)
  • 主機板支援 Mini-ITX, Micro-ATX, ATX, SSI-CEB, E-ATX* (*up to 12" x 10.7" motherboards, may impact cable management feature)
  • PCI 擴充槽 7
  • 3.5" 硬碟架 2
  • 2.5" 硬碟架 3
  • I/O 面板 - USB 埠 2x USB 3.2 Gen 1, 1x USB 3.2 Gen 2 type C
  • I/O 面板 - 音效輸入/輸出 1x Audio Jack
  • I/O 面板 - 其他 1x ARGB 風扇接口
  • 預裝風扇 - 上方 無
  • 預裝風扇 - 前方 3x 120mm CF120 ARGB
  • 預裝風扇 - 後方 1x 120mm CF120 ARGB
  • 風扇支援 - 上方 3x 120mm, 2x 140mm
  • 風扇支援 - 前方 3x 120mm, 2x 140mm
  • 風扇支援 - 後方 1x 120mm
  • 水冷支援 - 上方 120 / 140 / 240 / 280 / 360mm (recommended maximum thickness - 55mm)
  • 水冷支援 - 前方 120 / 140 / 240 / 280 / 360mm
  • 水冷支援 - 後方 120mm
  • 預留安裝空間 - CPU 散熱器 165mm
  • 預留安裝空間 - 電源供應器 200mm (Recommended up to 170mm)
  • 預留安裝空間 - 顯示卡 410mm
  • 電纜佈線 - 主板托盤後面 19mm
  • 防塵濾網 前方、上方、底部
  • 電源供應器類型 Bottom Mount, ATX
  • 保固 2 年
  • 尺寸 中直立式
  • 系列 MasterBox 系列
