MasterBox Q300L image number 4
MasterBox Q300L image number 5
MasterBox Q300L
MasterBox Q300L
MasterBox Q300L
MasterBox Q300L
MasterBox Q300L
MasterBox Q300L
Choose Your Style
MasterBox Q300L
The MasterBoxQ300L is your straightforward option in the lineup of the brand new MasterBoxQ-series from Cooler Master.
顏色
立即購買
Patterned Magnetic Dustfilters
Special pattern on the dust filter creates a unique outlook for the chassis.
Modular I/O Panel
Modular I/O Panel
The I/O panel can be adjusted to six different locations. On both side of the body you can install the I/O panel at the front, top or bottom.
Edge-To-Edge Side Panel
Show off your build through the full size transparent side panel.
Multiple Positioning Options
The case can be put in vertical or horizontal position.
Excellent Thermal Performance
The open design of the perforated front, top and bottom guarantees excellent thermal performance
Clean Routing Space
Behind the motherboard tray, 28mm of space is offered for cable management.
  • 產品型號 MCB-Q300L-KANN-S00
  • 顏色 黑
  • 材質 鋼材, 塑膠
  • 尺寸 (長x寬x高) 387 x 230 x 381mm
  • 主機板支援 Mini-ITX, Micro-ATX
  • PCI 擴充槽 4
  • 5.25" 硬碟架 0
  • 3.5" 硬碟架 1
  • 2.5" 硬碟架 2
  • I/O 面板 - USB 埠 2x USB 3.0
  • I/O 面板 - 音效輸入/輸出 1x 3.5mm Audio Jack, 1x 3.5mm Mic Jack
  • 預裝風扇 - 後方 1x 120mm
  • 風扇支援 - 前方 2x 120/140mm
  • 風扇支援 - 上方 2x 120mm
  • 風扇支援 - 後方 1x 120mm
  • 風扇支援 - 底部 1x 120mm
  • 水冷支援 - 前方 120 / 240mm
  • 水冷支援 - 前方 120mm
  • 水冷支援 - 後方 120mm
  • 預留安裝空間 - CPU 散熱器 159mm
  • 預留安裝空間 - 電源供應器 160mm
  • 預留安裝空間 - 顯示卡 360mm
  • 防塵濾網 底部
  • 電源供應器類型 Bottom Mount, ATX PS2
  • 保固 2 年
  • 尺寸 迷你直立式
  • 系列 MasterBox 系列
