MasterBox Q300L image number 4
MasterBox Q300L
MasterBox Q300L
MasterBox Q300L
MasterBox Q300L
MasterBox Q300L
Choose Your Style
MasterBox Q300L White Mini Tower PC Case
The MasterBox Q300L is your straightforward option in the lineup of the brand new MasterBox Q-series from Cooler Master.
顏色
立即購買
Multiple Positioning Options
Q300L White Edition
This the white edition of the award-winning MasterBox Q300L, time to get a clean pure-white build!
Modular I/O Panel
Edge-to-edge Side Panel
Excellent Thermal Performance
Fan And Radiator Support
The front supports up to two 140mm fans and up to a 240mm radiator.
The rear supports a 120mm fan or radiator and the top two 120mm fans.
All to ensure you don't have to compromise on performance.
Main Components Clearance
The MasterBox Q300L case supports CPU coolers up to a height of 159mm, graphics cards up to a length of 360mm, and power supplies up to a length of 160mm.
  • 產品型號 MCB-Q300L-WANN-S00
  • 顏色 白
  • 材質 鋼材, 塑膠
  • 尺寸 (長x寬x高) 387 x 230 x 381mm
  • 主機板支援 Mini-ITX, Micro-ATX
  • PCI 擴充槽 4
  • 5.25" 硬碟架 0
  • 3.5" 硬碟架 1
  • 2.5" 硬碟架 2
  • I/O 面板 - USB 埠 2x USB 3.0
  • I/O 面板 - 音效輸入/輸出 1x Audio Jack
  • 預裝風扇 - 後方 1x 120mm
  • 風扇支援 - 前方 2x 120/140mm
  • 風扇支援 - 上方 2x 120mm
  • 風扇支援 - 後方 1x 120mm
  • 風扇支援 - 底部 1x 120mm
  • 水冷支援 - 前方 120 / 240mm
  • 水冷支援 - 後方 120mm
  • 預留安裝空間 - CPU 散熱器 159mm
  • 預留安裝空間 - 顯示卡 360mm
  • 預留安裝空間 - 電源供應器 160mm
  • 整線空間 28mm
  • 防塵濾網 底部
  • 電源供應器類型 Bottom Mount, ATX PS2
  • 尺寸 迷你直立式
  • 系列 MasterBox 系列
