MasterBox NR200P image number 0
MasterBox NR200P image number 1
MasterBox NR200P image number 2
MasterBox NR200P image number 3
MasterBox NR200P image number 4
MasterBox NR200P image number 5
MasterBox NR200P image number 6
MasterBox NR200P image number 7
MasterBox NR200P image number 8
MasterBox NR200P image number 9
MasterBox NR200P image number 10
MasterBox NR200P image number 11
MasterBox NR200P image number 12
MasterBox NR200P image number 13
MasterBox NR200P image number 14
MasterBox NR200P image number 15
MasterBox NR200P image number 16
MasterBox NR200P image number 17
MasterBox NR200P image number 18
MasterBox NR200P image number 19
MasterBox NR200P
MasterBox NR200P
MasterBox NR200P
MasterBox NR200P
MasterBox NR200P
MasterBox NR200P
MasterBox NR200P
MasterBox NR200P
MasterBox NR200P
MasterBox NR200P
MasterBox NR200P
MasterBox NR200P
MasterBox NR200P
MasterBox NR200P
MasterBox NR200P
MasterBox NR200P
MasterBox NR200P
MasterBox NR200P
MasterBox NR200P
MasterBox NR200P
效能,不被尺寸侷限
MasterBox NR200P
MasterBox NR200P是酷碼小尺寸機殼系列產品,在僅僅18升的體積裡面,有著可媲美ATX機殼的強大效能、相容性以及散熱性,而多種便利設計,讓玩家們安裝電腦時可以更簡單快速。提供多個風扇安裝以及開放式架構設計,足夠的內部空間不論是一體式水冷或者塔散皆可相容,帶來可靠的散熱效率。
顏色
立即購買
Style without sacrifice
The MasterBox NR200P uses features normally found in stylish, high-end AT cases and cleverly utilizes space-saving measures to create a chassis taking up less than half the volume. Every feature is thoughtfully laid out in an 18-liter space to maximize component compatibility, thermal efficiency, and ease of assembly.
Keep cool with a highly vented side panel, or look cooler with a crystal-clear tempered glass panel; both are included to satisfy performance and style preferences. Fit large graphics cards in the 3-slot capable NR200P, or utilize the two vertical cards slots with the included PCI riser to turn graphics cards and heads by making the GPU the centerpiece of the PC. Seven possible fan mounts, ample ventilation, and generous liquid and air-cooler clearances keep even the most powerful systems running at their optimum temperatures and speeds. The chassis frame is wrapped in a sleek and tasteful powder-coated steel chassis that makes a statement on a desk.
Customization
LIMITED SIZE, UNLIMITED OPTIONS
The NR200P includes many features found in larger ATX chassis while retaining a space-efficient form factor. The NR200P comes with the choice of a vented steel side panel for unrestricted airflow, or a crystal-clear tempered glass side panel to reveal the beauty of a computing beast.
A PCI Riser is included for vertical GPU installation to better showcase it against the glass, or to feed it fresh air from the side with the vented panel.
Cooling System
UNRESTRICTED COOLING POTENTIAL
The NR200P can house up to 7 fans in total for every cooling configuration imaginable. Two 120mm Sickleflow fan are included. The compact structure can efficiently house CPU coolers up to 155mm in height and radiators up to 280mm in length, so even the hottest running hardware can't be held back.
Our Achievements
AWARDS
  • 產品型號 MasterBox NR200P: MCB-NR200P-KGNN-S00, MasterBox NR200P White: MCB-NR200P-WGNN-S00
  • 外觀顏色 Black, White / Grey
  • 材質 - 外部 SGCC Steel, Mesh, ABS Plastic
  • 材質 - 左側板 強化玻璃 x1, 穿孔鋼板 x1
  • 尺寸 (長x寬x高) 376 x 185 x 292mm (incl. Protrusions), 360 x 185 x 274mm (excl. Protrusions)
  • 容量 18.25L (不含突出物)
  • 主機板支援 Mini-ITX, Mini-DTX, Max. size: 244 x 226mm
  • PCI 擴充槽 3
  • 5.25" 硬碟架 0
  • 3.5" 硬碟架 1 (Max. 2)
  • 2.5"/3.5" 硬碟架 (複合式) 1
  • 2.5" 硬碟架 2 (Max. 3)
  • I/O 面板 - USB 埠 2x USB 3.2 Gen 1 (USB 3.0)
  • I/O 面板 - 音效輸入/輸出 3.5mm 耳麥複合插孔(音訊 + 麥克風)* 1
  • 配件 1x PCIe 3.0 x16 轉接線
  • 預裝風扇 - 上方 2x 120mm 650-1800RPM PWM (SickleFlow)
  • 預裝風扇 - 前方 無
  • 預裝風扇 - 後方 N/A
  • 預裝風扇 - 底部 N/A
  • 風扇支援 - 上方 2x 120mm
  • 風扇支援 - 側面 2x 120/140mm
  • 風扇支援 - 後方 1x 92mm
  • 風扇支援 - 底部 2x 120mm (假如顯卡寬度大於2.5個PCI槽, 建議使用較薄的風扇)
  • 水冷支援 - 上方 N/A
  • 水冷支援 - 左側 120 / 140 / 240 / 280mm (not compatible with vertical GPU installation)
  • 水冷支援 - 後方 92mm (無法與直立顯卡一起安裝)
  • 水冷支援 - 底部 120/240mm (recommended only for single slot water-cooled GPUs or vertically mounted GPUs)
  • 預留安裝空間 - CPU 散熱器 155mm (vented steel side panel), 153mm (tempered glass side panel), 76mm (GPU in vertical position)
  • 預留安裝空間 - 電源供應器 130mm
  • 預留安裝空間 - 顯示卡 L: 330mm (incl. power connector), H: 156mm (incl. power connector), W: 60mm (triple slot)
  • 防塵濾網 Bottom, Left, Right, Top Panels
  • 電源供應器類型 SFX, SFX-L
  • 保固 2 年
  • 尺寸 迷你 ITX
  • 系列 MasterBox 系列
  • 備註 本產品僅支援PCI-E 3.0裝置,如果要搭配使用PCI-E 4.0的顯示卡或其他產品,請在進入主機板BIOS設置,將PCI-E選項設定為PCI-E 3.0
  • 備註 當水冷安裝於底部時, 建議搭配單槽水冷顯卡或者垂直安裝顯示卡
