MasterBox NR200P V2 Mini-ITX PC Case image number 0
MasterBox NR200P V2 Mini-ITX PC Case image number 1
MasterBox NR200P V2 Mini-ITX PC Case image number 2
MasterBox NR200P V2 Mini-ITX PC Case image number 3
MasterBox NR200P V2 Mini-ITX PC Case image number 4
MasterBox NR200P V2 Mini-ITX PC Case image number 5
MasterBox NR200P V2 Mini-ITX PC Case image number 6
MasterBox NR200P V2 Mini-ITX PC Case image number 7
MasterBox NR200P V2 Mini-ITX PC Case image number 8
MasterBox NR200P V2 Mini-ITX PC Case image number 9
MasterBox NR200P V2 Mini-ITX PC Case image number 10
MasterBox NR200P V2 Mini-ITX PC Case image number 11
MasterBox NR200P V2 Mini-ITX PC Case image number 12
MasterBox NR200P V2 Mini-ITX PC Case image number 13
MasterBox NR200P V2 Mini-ITX PC Case image number 14
MasterBox NR200P V2 Mini-ITX PC Case image number 15
MasterBox NR200P V2 Mini-ITX PC Case image number 16
MasterBox NR200P V2 Mini-ITX PC Case image number 17
MasterBox NR200P V2 Mini-ITX PC Case image number 18
MasterBox NR200P V2 Mini-ITX PC Case image number 19
MasterBox NR200P V2 Mini-ITX PC Case image number 20
MasterBox NR200P V2 Mini-ITX PC Case image number 21
MasterBox NR200P V2 Mini-ITX PC Case image number 22
MasterBox NR200P V2 Mini-ITX PC Case image number 23
MasterBox NR200P V2 Mini-ITX PC Case image number 24
MasterBox NR200P V2 Mini-ITX PC Case image number 25
小巧設計,無限可能
Step into a world of elegant and sophisticated functionality with the NR200P V2. The V2 showcases features typically reserved for high-end
顏色
立即購買
Cooling System
240-280MM
LIQUID COOLERS
18.25L
ULTRA-SLEEK DESIGN
Extra Cool
120MM
BOTTOM FAN
COMPREHENSIVE GPU SUPPORT
Includes vertical mounting options, a custom PCle 4.0 riser cable, and a support bracket for GPUs up to 356mm in length and 160mm in height.
  • 產品型號 MasterBox NR200P V2: NR200PV2-KCNN-S00, MasterBox NR200P V2 White: NR200PV2-WCNN-S00
  • 外觀顏色 Black, White / Grey
  • 材質 - 外部 SGCC Steel, Mesh, ABS Plastic
  • 材質 - 左側板 強化玻璃 x1, 穿孔鋼板 x1
  • 尺寸 (長x寬x高) 372 x 185 x 292mm (incl. Protrusions), 360 x 185 x 274mm (excl. Protrusions)
  • 容量 18.25L
  • 主機板支援 Mini-ITX, Max. size: 170 x180mm
  • PCI 擴充槽 3
  • 5.25" 硬碟架 0
  • 3.5" 硬碟架 1 (最多2個, 需移除底部風扇)
  • 2.5"/3.5" 硬碟架 (複合式) 1
  • 2.5" 硬碟架 1 (最多2個)
  • I/O 面板 - USB 埠 2x USB 3.2 Gen 1 (USB 3.0), 1x USB 3.2 Gen 2x2 Type C
  • I/O 面板 - 音效輸入/輸出 3.5mm 耳麥複合插孔(音訊 + 麥克風)* 1
  • 包含配件 1x PCIe 4.0 x16 riser cable, 1x GPU Holder
  • 預裝風扇 - 上方
  • 預裝風扇 - 前方
  • 預裝風扇 - 後方 N/A
  • 預裝風扇 - 底部 1x 120mm 650~1800rpm PWM SickleFlow
  • 風扇支援 - 上方 2x 120/140mm
  • 風扇支援 - 側面 N/A
  • 風扇支援 - 後方 N/A
  • 風扇支援 - 底部 2x 120mm (1x 最大 15mm , 底部未安裝HDD)
  • 水冷支援 - 上方 120 / 140 / 240 / 280mm
  • 水冷支援 - 側面 N/A
  • 水冷支援 - 後方 N/A
  • 水冷支援 - 底部 N/A
  • 預留安裝空間 - CPU 散熱器 67mm
  • 預留安裝空間 - 電源供應器 130mm
  • 預留安裝空間 - 顯示卡 超出前支架:長度: 357mm (含電源接頭), 高度: 160mm (含電源接頭), 寬度: 73mm (三槽位); 未超出前支架:長度: 334mm (含電源接頭), 高度: 160mm (含電源接頭), 寬度: 80mm (三槽位)
  • 防塵濾網 Bottom, Left, Right, Top Panels
  • 電源供應器類型 SFX, SFX-L
  • 保固 2 年
  • 系列 MasterBox 系列
  • 尺寸 迷你 ITX
