MasterBox MB511 ARGB image number 0
MasterBox MB511 ARGB image number 1
MasterBox MB511 ARGB image number 2
MasterBox MB511 ARGB image number 3
MasterBox MB511 ARGB image number 4
就位、預備、認真打 GAME
搭配 MasterBox MB511 ARGB ATX 電腦機殼,為高規格遊戲打造的主機能透過精密網孔前面板輕鬆呼吸。前方帶有侵略性的進氣設計,結合通風上蓋,帶來更多的散熱支援能力。Cooler Master 具有代表性的精密網孔布滿整個前面板,不僅維持遊戲主機的涼爽,更能保持清潔。
立即購買
Your Search For Airflow Ends Here.
By employing Cooler Master’s Fine Mesh technology, the MasterBox MB511 ARGB demonstrates a prowess for thermal performance and pairs it with premium lighting. Three ARGB fans are included in the box to complement hardware lighting while mesh ventilation on the front and top panel keeps gaming systems cool under pressure.
With airflow potential and aesthetic customization maximized, high-demand gaming rigs can breathe easy in the MasterBox MB511 ARGB.
Fine Mesh Front Panel
The Fine Mesh design on the front panel is proven, by reviewers and critics alike, to provide considerable airflow while simultaneously filtering out dust. Light also refracts and behaves uniquely to the Fine Mesh, creating a halo effect against the included ARGB fans.
ARGB Lighting System
Three pre-installed ARGB fans can be managed by either the motherboard or an included controller, connected by the included splitter, to create a comprehensive ARGB lighting system.
Tempered Glass Side Panel
Gaming hardware, cooling components, and the pure pride of the builder is shown in panoramic view through an edge-to-edge tempered glass side panel.
Versatile Cooling Options
Support for up to seven 120mm fans and dual 360mm radiators on the top and front panel ensure that even the most extreme systems stay cool.
  • 產品型號 MCB-B511D-KGNN-RGA
  • 顏色 黑
  • 材質 - 外部 Steel, Plastic
  • 材質 - 左側板 Tempered Glass, Steel
  • 尺寸 (長x寬x高) 496 x 217 x 469 mm
  • 主機板支援 Mini-ITX, Micro-ATX, ATX, SSI-CEB, E-ATX* (*up to 12" x 10.7" motherboards)
  • PCI 擴充槽 7
  • 5.25" 硬碟架 無
  • 2.5"/3.5" 硬碟架 (複合式) 2 (最大 2 組)
  • 2.5" 硬碟架 5 (最大 6 組)
  • I/O 面板 - USB 埠 2x USB 3.2 Gen 1 (USB 3.0)
  • I/O 面板 - 音效輸入/輸出 1x 3.5mm Audio Jack, 1x 3.5mm Mic Jack
  • I/O 面板 - 其他 1x ARGB Controller, 1x ARGB 2-to-3 Splitter
  • 預裝風扇 - 前方 3x 120mm ARGB 風扇
  • 風扇支援 - 上方 3x 120mm, 2x 140mm
  • 風扇支援 - 前方 3x 120mm / 2x 140mm (140mm can only mount behind the front plate)
  • 風扇支援 - 後方 1x 120mm
  • 水冷支援 - 上方 120 / 240 / 360mm (44mm max motherboard component height)
  • 水冷支援 - 前方 120 / 140 / 240 / 280 / 360mm (75mm clearance)
  • 水冷支援 - 後方 120mm
  • 預留安裝空間 - CPU 散熱器 165mm
  • 預留安裝空間 - 電源供應器 180mm/7.08"
  • 預留安裝空間 - 顯示卡 410mm
  • 防塵濾網 前方、上方、底部
  • 電源供應器類型 Bottom Mount, ATX
  • 保固 2 年
  • 尺寸 中直立式
  • 系列 MasterBox 系列
