MasterAir MA824 Stealth 30th Anniversary Edition CPU Air Cooler image number 0
MasterAir MA824 Stealth 30th Anniversary Edition CPU Air Cooler image number 1
MasterAir MA824 Stealth 30th Anniversary Edition CPU Air Cooler image number 2
MasterAir MA824 Stealth 30th Anniversary Edition CPU Air Cooler image number 3
MasterAir MA824 Stealth 30th Anniversary Edition CPU Air Cooler image number 4
MasterAir MA824 Stealth 30th Anniversary Edition CPU Air Cooler image number 5
MasterAir MA824 Stealth 30th Anniversary Edition CPU Air Cooler image number 6
MasterAir MA824 Stealth 30th Anniversary Edition CPU Air Cooler image number 7
The MA824 Stealth is bringing performance ready to overshadow it’s competition.
MA824 Stealth 30TH Anniversary Edition carries the Stealth identity with total blackout accents and design, in addition to the 30th Anniversary logo and silkscreen print. With an impressive 8 heat pipes & dual tower design, the MA824 Stealth delivers unmatched performance in it’s class. Upgraded with the 30th Anniversary 120mm Mobius Fan, the 135mm fan provide absolute cooling performance in a Push – Pull configuration. The MA824 Stealth is bringing performance ready to overshadow it’s competition.
8
HEAT PIPES
Cooling System
Full
Coverage Base
The full coverage nickel plated copper base provides seamless
contact and complete coverage to minimize heat zones.
Special Edition
30TH
ANNIVERSARY DESIGN
Tech Specs
& Downloads
Dual Tower
Performance
Dual Tower
Redesigned dual tower maximizes performance and surface area with optimized fin density and thickness.
Dual Mobius Fan
Performance
Dual Mobius Fan
Dual Mobius fans with balanced air flow and pressure perfect the push-pull setup for maximum heat dissipation.
  • 產品型號 MAM-D8PN-318PK-30
  • 外觀顏色 黑色
  • CPU 腳位 Intel® LGA 1851 / 1700 / 1200 / 1151 / 1150 / 1155 / 1156 socket
  • CPU 腳位 AMD® AM5 / AM4 Socket
  • 尺寸 (長 x 寬 x 高) 162.2 x 150.6 x 165.6 mm
  • 散熱器材質 8根熱管 / 鋁製散熱片
  • 風扇尺寸 (長 x 寬 x 高) 135mm 風扇: 135 x 135 x 26 mm
  • 風扇設定檔 135mm Fan: Non-Led
  • 風扇數量 1 個
  • 風扇轉速 135mm 風扇: 0-1550 RPM ± 15%
  • 風扇風量 135mm 風扇: 63.6 CFM (最大), 120mm 風扇: 75.2 CFM (最大)
  • 風扇壓力 135mm 風扇: 1.92 mmH₂O
  • 風扇平均故障間隔 >200,000 小時
  • 風扇噪音水平 135mm 風扇: 24.6 dBA (最大), 120mm 風扇: 30 dBA (Max)
  • 風扇軸承類型 循環動態軸承 (Loop Dynamic Bearing, LDB)
  • 風扇連接介面 4-Pin (PWM)
  • 風扇額定電壓 12 VDC
  • 風扇額定電流 135mm 風扇: 0.1 A
  • 風扇安全電流 135mm Fan: 0.25A
  • 風扇功耗 135mm 風扇: 1.2-2.4W
  • 產品保固 5年
  • 產品類型 CPU空冷散熱器
  • 系列 MasterAir
  • 熱導管數量 8
