LED 控制器A1 image number 0
LED 控制器A1 image number 1
LED 控制器A1 image number 2
LED 控制器A1 image number 3
LED 控制器A1 image number 4
LED 控制器A1
LED 控制器A1
LED 控制器A1
LED 控制器A1
LED 控制器A1
小巧、純粹、多變
LED 控制器A1
酷碼全新設計的Gen2 ARGB LED控制器,讓您可以更輕易來客製化電腦的燈光效果。
立即購買
LED Controller A1
Cooler Master has engineered the new Addressable Gen 2 RGB LED Controller granting you the versatility to easily personalize your devices delivered to you in a small compact size.
Simple And Compact
No need to hassle with an ARGB capable motherboard or complex software. With 3 ARGB headers available, each header can connect up to 80 individual LEDs for a total of up to 240 LEDs.
A. 5V SATA Power Connector
B. 9 Pin USB Connector
C. 5V 3 Pin ARGB Connector
Backwards Compatibility
Compatible with both Gen 2 ARGB and standard ARGB devices, connect all your devices with the simple touch of a button.
New Addressable Gen 2 RGB
Addressable Gen 2 RGB controller works with Cooler Master's MasterPlus+ software, allowing you to customize each individual LED's color, effect, brightness, and more – all from an intuitive, convenient interface.
  • 產品型號 MFY-ACBN-NNUNN-R2
  • 顏色 黑色
  • 材質 塑膠
  • 尺寸 (長 x 寬 x 高) 84.7 x 51.7 x 15.3 mm
  • 接頭 3 ports x 3 Pin Addressable RGB
  • 額定電壓 5 VDC
  • 安全電流 2.0 (1 port) / Total 4.5 A (3 port)
  • 供電介面 SATA
  • 電源安全電流 4.5 A (最大)
  • USB Micro USB x 1
  • 重量 90g
  • 產品保固 2年
  • 產品類型 RGB週邊
