Hyper 212 Pro image number 0
Hyper 212 Pro image number 1
Hyper 212 Pro image number 2
Hyper 212 Pro image number 3
Hyper 212 Pro image number 4
Hyper 212 Pro
Hyper 212 Pro
Hyper 212 Pro
Hyper 212 Pro
Hyper 212 Pro
Cool Efficiency Redefined
Hyper 212 Pro
Superconductive Composite Heat Pipes
Higher TDP
Optimized Tower Cooler Design
100% RAM Clearance
SickleFlow Edge 120 Fans
Cooler Master’s masterclass HYPER 212 series makes a triumphant return with the HYPER 212 PRO, a new take on a classic design featuring our in-house design heat pipes.
The optimized design ensures better airflow and heat dissipation, which results in improved cooling efficiency and overall system performance.
By using various evaporator and condensor wick structures, our SCHPs greaty enhance performace for improved heat dissipation
All-new Top Cover Design
A sleek and modern top cover enhances the overall look of your build, giving it a stylish and professional appearance.
A SickleFlow Edge fan combines exceptional heat dissipation performance with a visually striking design.
Easy fan mount
Simplifies the installation process, allowing users to set up the cooler quickly and efficiently.
  • 產品型號 RR-212S-25PZ-R1
  • 外觀顏色 黑色
  • CPU 腳位 Intel® LGA 1851 / 1700 / 1200 / 1151 / 1150 / 1155 / 1156 socket
  • CPU 腳位 AMD® AM5 / AM4 Socket
  • 尺寸 (長 x 寬 x 高) 125 x 74 x 152 mm
  • 散熱器材質 4根熱管 / 直觸 / 鋁製散熱片
  • 設定檔 Addressable Gen 2 RGB
  • 風扇數量 1 個
  • 風扇轉速 690-2500 RPM ± 10%
  • 風扇風量 70.7 CFM (最大)
  • 風扇壓力 3.61 mmH₂O (Max)
  • 風扇平均故障間隔 >160,000 小時
  • 風扇噪音水平 32.8 dBA (Max)
  • 風扇軸承類型 循環動態軸承 (Loop Dynamic Bearing, LDB)
  • 風扇連接介面 4-Pin (PWM)
  • 風扇額定電壓 12 VDC
  • 風扇額定電流 0.2A
  • 風扇安全電流 0.3A
  • 風扇功耗 2.4W
  • 產品保固 2年
  • 產品類型 CPU空冷散熱器
  • 系列 Hyper
  • 熱導管數量 4
