Hybrid 1 電競混血椅 30週年紀念版 image number 0
Hybrid 1 電競混血椅 30週年紀念版 image number 1
Hybrid 1 電競混血椅 30週年紀念版 image number 2
Hybrid 1 電競混血椅 30週年紀念版 image number 3
Hybrid 1 電競混血椅 30週年紀念版 image number 4
Hybrid 1 電競混血椅 30週年紀念版 image number 5
Hybrid 1 電競混血椅 30週年紀念版 image number 6
Hybrid 1 電競混血椅 30週年紀念版 image number 7
Hybrid 1 電競混血椅 30週年紀念版 image number 8
Hybrid 1 電競混血椅 30週年紀念版 image number 9
Hybrid 1 電競混血椅 30週年紀念版 image number 10
Hybrid 1 電競混血椅 30週年紀念版 image number 11
Hybrid 1 電競混血椅 30週年紀念版 image number 12
Hybrid 1 電競混血椅 30週年紀念版 image number 13
Hybrid 1 電競混血椅 30週年紀念版 image number 14
Hybrid 1 電競混血椅 30週年紀念版 image number 15
Hybrid 1 電競混血椅 30週年紀念版 image number 16
Hybrid 1 電競混血椅 30週年紀念版 image number 17
Hybrid 1 電競混血椅 30週年紀念版 image number 18
Hybrid 1 電競混血椅 30週年紀念版 image number 19
Hybrid 1 電競混血椅 30週年紀念版 image number 20
Hybrid 1 電競混血椅 30週年紀念版 image number 21
Hybrid 1 電競混血椅 30週年紀念版 image number 22
完美平衡的混血產物
在外觀與舒適上,Hybrid 1 電競混血椅 30週年紀念版提供一個不妥協的體驗。
The Best of Both Worlds
In a world of comfort and expression, the 30th Anniversary Edition Hybrid 1 is a special version of the current Hybrid 1. Hybrid 1 combines the benefits of comfort-driven office chairs with support-based racing seats that allow ergonomic customization to a user’s preference for maximum airflow during longer sessions. 30th Anniversary edition is styled particularly on the front and back end of the headrest, along with a rainbow-colored pulley.
Professional and Clean
A professional office design melded together with a gaming racing chair, Hybrid 1's premium materials and clean aesthetic is perfect for blending into any type of environment such as an office environment or your personal gaming setup back at home.
MUSCLEFLEX® MESH
FULLY-ADJUSTABLE LUMBAR SUPPORT
ADJUSTABLE NECK SUPPORT
3D ARMREST
High-Density Molded Foam
Hybrid 1 is designed to offer an all-day comfortable seating experience, built with high-density molded foam that provides extra cushioning for the best sitting experience. The premium plush materials ensure you'll remain comfortable even after extended periods of sitting.
Advanced Air Ventilation
Using our exclusive cold molded-foam technology in the seat base of the Hybrid 1, air ventilation is vastly improved leading to reduced heat buildup. The premium molded foam serves as an extremely comfortable base, conforming to your body and allowing you to sit on the Hybrid 1 for even the longest of work and play days.
Premium Steel Frame and Aluminum Base Construction
Comprised with a rock-steady steel frame in combination with a premium aluminum base, the Hybrid 1 is built with high-quality materials that is not only reliable, but will last for years on end.
75mm SILENT CASTERS
Large premium caster wheels roll exceptionally well on all surfaces while producing less noise than traditional casters.
PRECISION CLASS 4 GAS LIFT
With a premium precision class 4 gas lift, Hybrid 1's height adjustments are accurate and reliable every time.
  • 產品型號 CMI-GCHYB1-BK30TH
  • 顏色 30週年限量版
  • 整體高度範圍 124-134 cm
  • 椅背高度 78 cm
  • 靠背寬度 54 cm
  • 扶手到扶手寬度 75 cm
  • 座椅寬度 (含側邊) 61 cm
  • 可坐範圍 61 cm
  • 座椅深度 54 cm
  • 本體直徑 68 cm
  • 鋼板厚度 1.5 mm
  • 扶手可調範圍 29-36 cm
  • 地板至椅墊高度 48-58 cm
  • 高度可調範圍 10 cm
  • 可調後仰角度 90-180 度
  • 扶手 3D
  • 頭枕 整合式頭枕 (上/下)
  • 腰部支援 2D 腰部支援 (上/下, 前/後)
  • 外部用料 背靠: MuscleFlex® Mesh
  • 內部用料 高密度冷成形泡沫
  • 框體材質 金屬
  • 底座材質 (腳) 鋁合金
  • 滾輪 75 mm
  • 氣壓棒 Class 4
  • 淨重 26.3 kg
  • 毛重 31.2 kg
  • 最大負重 150 kg
  • 產品保固 2 年
  • 產品分類 電競椅
  • 電競椅系列 Hybrid 系列
