The Best of Both Worlds
Hybrid 1 combines the benefits of comfort-driven office chairs with support-based racing seats, bridging the void between gamers and professional workers. Driven by extensive research, fully fleshed-out ergonomics combined with a unique identity is what truly makes the Hybrid 1 the best of both worlds.
Perfect for Any Scenario
Designed specifically for those who spend extensive amount of hours staying seated for work as well as play, the Hybrid 1's clean, professional aesthetic with a full array of ergonomic features makes it the perfect addition to your setup.
Professional and Clean
A professional office design melded together with a gaming racing chair, Hybrid 1's premium materials and clean aesthetic is perfect for blending into any type of environment such as an office environment or your personal gaming setup back at home.
MUSCLEFLEX® MESH
FULLY-ADJUSTABLE LUMBAR SUPPORT
ADJUSTABLE NECK SUPPORT
3D ARMREST
High-Density Molded Foam
Hybrid 1 is designed to offer an all-day comfortable seating experience, built with high-density molded foam that provides extra cushioning for the best sitting experience. The premium plush materials ensure you'll remain comfortable even after extended periods of sitting.
Advanced Air Ventilation
Using our exclusive cold molded-foam technology in the seat base of the Hybrid 1, air ventilation is vastly improved leading to reduced heat buildup. The premium molded foam serves as an extremely comfortable base, conforming to your body and allowing you to sit on the Hybrid 1 for even the longest of work and play days.
Premium Steel Frame and Aluminum Base Construction
Comprised with a rock-steady steel frame in combination with a premium aluminum base, the Hybrid 1 is built with high-quality materials that is not only reliable, but will last for years on end.
Recline the Way You Want
Fully adjust the recline of the chair to whichever angle you want. Keep the recline at a sturdy upright 90 degrees for when you need to focus or get into the heat of the game, or adjust further back down for when you need to rest and relax.
75mm SILENT CASTERS
Large premium caster wheels roll exceptionally well on all surfaces while producing less noise than traditional casters.
PRECISION CLASS 4 GAS LIFT
With a premium precision class 4 gas lift, Hybrid 1's height adjustments are accurate and reliable every time.
@ Cooler Master Technology Inc. (VAT: 54272387)
