HAF 700 EVO image number 0
HAF 700 EVO image number 1
HAF 700 EVO image number 2
HAF 700 EVO image number 3
HAF 700 EVO image number 4
HAF 700 EVO image number 5
HAF 700 EVO image number 6
HAF 700 EVO image number 7
HAF 700 EVO image number 8
HAF 700 EVO image number 9
HAF 700 EVO image number 10
HAF 700 EVO image number 11
HAF 700 EVO image number 12
HAF 700 EVO image number 13
HAF 700 EVO image number 14
HAF 700 EVO image number 15
HAF 700 EVO image number 16
HAF 700 EVO image number 17
HAF 700 EVO image number 18
HAF 700 EVO image number 19
HAF 700 EVO
HAF 700 EVO
HAF 700 EVO
HAF 700 EVO
HAF 700 EVO
HAF 700 EVO
HAF 700 EVO
HAF 700 EVO
HAF 700 EVO
HAF 700 EVO
HAF 700 EVO
HAF 700 EVO
HAF 700 EVO
HAF 700 EVO
HAF 700 EVO
HAF 700 EVO
HAF 700 EVO
HAF 700 EVO
HAF 700 EVO
HAF 700 EVO
只因完美而生
HAF 700 EVO
HAF 700 EVO不僅傳承HAF系列的散熱與性能表現,更為延續其脫俗的精神而精心設計,讓經典傳奇再造巔峰。
顏色
CREATED ONLY FOR THE BEST
Rediscover PC DIY: a form of entertainment, a polished skillset, an exquisite art form, and a way of living.
Our Achievements
12 Awards
No Limits
Hardware & Connectivity
No Limits
The HAF 700 EVO is capable of housing up to SSI-EEB motherboards (E-ATX), as well as any sized graphics cards in BOTH horizontal and vertical orientations.
View ports & slots
Cooling Options
EXCLUSIVE SICKLEFLOW FANS
HAF 700 EVO comes with dual exclusive 200mm SickleFlow PWM "Performance Edition" fans tailored to strike a balance between performance potential and noise levels.
Custom Cooling
6x
MAMMOTH RADIATOR SUPPORT
Effortless Management
12x
INTEGRATED HUB
REMOVABLE TOP PANEL
The unique removable top panel design allows you to effortlessly install, reach and maintain cooling components such as fans and radiators even in builds with complex custom cooling systems.
Air Flow
透過 LCD 顯示的開機畫面來辨識您的 HAF 700 EVO
Edge Lit Intake Blades
Design
Sleek, premium tempered glass or performant mesh? Why choose? Thick, robust ARGB tempered glass Intake Blades create unique, futuristic lighting effects while maintaining the thermal efficiency and performance of mesh that you love.
Design
VERTICAL GPU HOLDER WITH PCIE 4.0 RISER CABLE
An included vertical graphics card holder with PCle 4.0 riser cable grant users the flexibility of choice in aesthetic display and airflow performance.
Design
INFINITY MIRROR
...Because what's the point of owning a flagship case without having
a bit of fun? The Infinity Mirror allows you to turn extra clearance in
the build into your personal Hall of Fame.
Design
MULTI CHAMBER LAYOUT
HAF 700 EVO's structure segregates non heat sensitive components so heat dissipation can be targeted towards heat sensitive components at an overall higher efficiency.
Design
TOOL-LESS INSTALLATION
  • 產品型號 HAF 700 EVO: H700E-IGNN-S00, HAF 700 EVO White: H700E-WGNN-S00
  • 外觀顏色 HAF 700 EVO: 鈦灰, HAF 700 EVO 白色版: 白
  • 材質 - 外部 Mesh, Steel, Plastic
  • 材質 - 左側板 Tempered Glass, Steel
  • 尺寸 (長x寬x高) 556 x 279 x 540 mm (本體尺寸), 666 x 291 x 626 mm (包括突出物)
  • 主機板支援 Mini-ITX, Micro-ATX, ATX, E-ATX, SSI-CEB, SSI-EEB
  • PCI 擴充槽 8
  • 5.25" 硬碟架
  • 2.5"/3.5" 硬碟架 (複合式) 12
  • 2.5" 硬碟架 12
  • I/O 面板 - USB 埠 1x USB 3.2 Gen 2 Type C, 4x USB 3.2 Gen 1 (3.0)
  • I/O 面板 - 音效輸入/輸出 1x 3.5mm 4 Poles Audio Jack, 1x 3.5mm Mic Jack
  • I/O 面板 - 其他 1x LED Controller A1 (ARGB Gen2), 1x ARGB/PWM Hub
  • 預裝風扇 - 前方 HAF 700 EVO: 2x SickleFlow PWM Performance Ed. 200mm, HAF 700 EVO 白色版: 2x SickleFlow White PWM Performance Ed. ARGB 200mm
  • 預裝風扇 - 後方 HAF 700 EVO: 2x SickleFlow PWM ARGB 120mm, HAF 700 EVO 白色版: 2x SickleFlow White PWM ARGB 120mm
  • 預裝風扇 - 底部 HAF 700 EVO: 1x SickleFlow PWM ARGB 120mm, HAF 700 EVO 白色版: 1x SickleFlow White PWM ARGB 120mm
  • 風扇支援 - 上方 2x 200mm, 3x 140mm, 6x 120mm (Remove 480mm bracket)
  • 風扇支援 - 前方 2x 200mm, 3x 120/140mm
  • 風扇支援 - 後方 2x 120mm
  • 風扇支援 - 底部 3x 120/140mm
  • 風扇支援 - 側面 4x 120mm / 3x 140mm
  • 水冷支援 - 上方 最高可支援 2x 360mm / 1x 420mm
  • 水冷支援 - 前方 最高可支援 420/360mm
  • 水冷支援 - 後方 最高可支援 240mm
  • 水冷支援 - 底部 最高可支援 420/360mm
  • 水冷支援 - 側面 最高可支援 480/420mm
  • 預留安裝空間 - CPU 散熱器 166mm
  • 預留安裝空間 - 電源供應器 200mm
  • 預留安裝空間 - 顯示卡 490mm
  • 電纜佈線 - 主板托盤後面 90-101mm
  • 包含配件 HAF 700 EVO: 通用型顯示卡支架套件 V2, HAF 700 EVO White: 通用型顯示卡支架套件 V3 白色版
  • 防塵濾網 Front, Bottom, Side
  • 電源供應器類型 Bottom Mount, ATX
  • 保固 2 年
  • 尺寸 高直立式
  • 系列 HAF 系列
  • 備註 * 支援一般 30mm 厚度水冷排, 如使用加厚的水冷排, 請參考使用手冊
