HAF 500 中直立式機殼 image number 0
HAF 500 中直立式機殼 image number 1
HAF 500 中直立式機殼 image number 2
HAF 500 中直立式機殼 image number 3
HAF 500 中直立式機殼 image number 4
HAF 500 中直立式機殼
HAF 500 中直立式機殼
HAF 500 中直立式機殼
HAF 500 中直立式機殼
HAF 500 中直立式機殼
不敗經典,風華再現
HAF 500 中直立式機殼
效能超群的HAF系列帶著HAF500強勢回歸
顏色
立即購買
Homecoming Classic
Cooler Master’s classic HAF series is making a return with HAF 500.
Built for high airflow and peak performance, the HAF 500 boasts iconic 200mm large intake ARGB fans, ensuring unparalleled intake and cooling efficiency.
The chassis features a dedicated GPU fan, adjustable to various GPU lengths. Ample clearance for dual 360mm radiators on the top and front panel accommodates the most advanced water cooling setups.
Tool-less side panels and a removable top panel facilitates simplified, hassle-free component installation without the need to struggle with small spaces.
Homecoming Classic
Homecoming Classic
Airflow
Mesh Front Panel
Large filtered intakes promotes high airflow, keeping internal components
running at optimal temperature
Our Achievements
Awards
Cooling System
GPU
120mm fan
Fans
Dual 200mm ARGB fans
Iconic 200mm ARGB fans embedded in the core of the HAF Series
in design and function move high volumes of air quietly and effectively
due to their large size. Utilizing the included hub, ARGB lighting can be
customized to create a comprehensive theme to match your build.
USB 3.2 gen 2 type C support
Ports & Slots
USB 3.2 Gen 2 Type C ports built into the I/O panel allows multi-purpose, streamlined data transmission.
Removable top panel
The top panel is entirely removable for improved access to the components during assembly. Ease of use also facilitates the mounting of cooling solutions such as fans and radiators.
VERSATILE COOLING OPTIONS
Support for up to eight 120mm fans and dual 360mm radiators on the top and front panel ensure high compatibility for liquid-cooled systems.
  • 產品型號 HAF 500: H500-KGNN-S00, HAF 500 White: H500-WGNN-S00
  • 外觀顏色 HAF 500: Black, HAF 500 White: White
  • 材質 - 外部 Steel, Mesh, Plastic
  • 材質 - 左側板 Tempered Glass, Steel
  • 尺寸 (長x寬x高) 516 x 224 x 510mm (包括突出物)
  • 主機板支援 ITX, M-ATX, ATX, SSI CEB, E-ATX* (*up to 12"x14.1", may impact cable management and case features)
  • PCI 擴充槽 7
  • 5.25" 硬碟架 無
  • 2.5"/3.5" 硬碟架 (複合式) 2
  • 2.5" 硬碟架 2
  • I/O 面板 - USB 埠 2x USB 3.2 Gen 1 (USB 3.0), 1x USB 3.2 Gen 2 type C
  • I/O 面板 - 音效輸入/輸出 1x single Audio jack
  • I/O 面板 - 其他 1x ARGB Hub
  • 預裝風扇 - 前方 2x 200mm ARGB 風扇
  • 預裝風扇 - 後方 1x 120mm SickleFlow PWM ARGB
  • 預裝風扇 - 硬碟架上方 1x 120mm SickleFlow PWM
  • 風扇支援 - 上方 3x 120mm / 2x 140mm / 2x 200mm
  • 風扇支援 - 前方 3x 120mm / 2x 140mm / 2x 200mm (*200mm Mounting Hole Spacing 154 x 154 w/ up to 30mm thickness)
  • 風扇支援 - 後方 1x 120mm
  • 風扇支援 - 硬碟架上方 1x 120mm
  • 水冷支援 - 上方 120 / 140 / 240 / 280 / 360mm
  • 水冷支援 - 前方 120 / 140 / 200 / 240 / 280 / 360mm
  • 水冷支援 - 後方 120mm
  • 預留安裝空間 - CPU 散熱器 167mm
  • 預留安裝空間 - 電源供應器 180mm
  • 預留安裝空間 - 顯示卡 410mm
  • 電纜佈線 - 主板托盤後面 30mm
  • 防塵濾網 上方、底部
  • 電源供應器類型 Bottom Mount, ATX
  • 保固 2 年
  • 尺寸 中直立式
  • 系列 HAF 系列
