GX III Gold 1250 ATX 3.1 White Edition image number 0
GX III Gold 1250 ATX 3.1 White Edition image number 1
GX III Gold 1250 ATX 3.1 White Edition image number 2
GX III Gold 1250 ATX 3.1 White Edition image number 3
GX III Gold 1250 ATX 3.1 White Edition image number 4
GX III Gold 1250 ATX 3.1 White Edition image number 5
GX III Gold 1250 ATX 3.1 White Edition image number 6
GX III Gold 1250 ATX 3.1 White Edition image number 7
Strength in Elegance
• Titanium efficiency at light loads
• Fully modular cabling
• 10-year warranty
Innovative, Streamlined Design
ATX 3.1 Support & a Durable 90-degree 12V-2x6 Cable
Includes ATX 3.1 support and a 90-degree 12V-2X6 PCle 5.1 connector featuring higher electrical durability, improved safety, and capable of bringing up to 600W to your GPU.
Exceptional Efficiency
This 80 Plus Gold certified unit can achieve Titanium level efficiency at light loads in a 115V test.
Optimized Thermal Performance
An anodic-coated heat sink keeps average temperatures 5℃ lower than a traditional heat sink for enhanced durability and a prolonged life span.
Fully Modular Cabling
Zero-RPM Mode
This unit includes a smart thermal control mode that defaults to zero spin.
PSU Calculator
  • 型號 MPX-C503-AFAG-EG
  • ATX 版本 ATX 12V Ver. 3.1
  • 功率因數校正 主動式 PFC
  • 輸入電壓 100-240V
  • 輸入電流 15-7A
  • 輸入頻率 50-60Hz
  • 尺寸 (長 x 寬 x 高) 160 x 150 x 86 mm
  • 風扇尺寸 135mm
  • 風扇軸承 FDB
  • 風扇轉速 2300 RPM
  • 轉換效率 典型轉換 ≥90%
  • 80 PLUS 評級 80 PLUS 金牌
  • ErP 2014 Lot 3 符合
  • 工作溫度 0-50°C
  • 電源良好信號 100 - 150 ms
  • 持續輸出時間 ≥ 16ms
  • 平均故障間隔 (MTBF) >100,000 小時
  • 保護機制 OPP/ OVP/ OTP/ OCP/ SCP/ UVP/ Surge & Inrush Protection
  • 安規 cTUVus, TUV, CE, FCC, BSMI, CCC, EAC, RCM, UKCA, RoHS2.0 / BIS, KC (Based on region's requests.)
  • ATX 24 Pin 電源接頭 1
  • EPS 4+4 Pin 電源接頭 1
  • EPS 8 Pin 電源接頭 1
  • SATA 電源接頭 12
  • 周邊 4 Pin 電源接頭 4
  • PCI-e 6+2 Pin 電源接頭 3
  • 12V-2x6 接頭 1
  • 產品系列 GX 系列
  • 80 Plus 金牌認證
  • 模組化 全模組化
  • 分類 750瓦以上
  • Watts 1250W
