GM34-CWQ2 電競螢幕 image number 0
GM34-CWQ2 電競螢幕 image number 1
GM34-CWQ2 電競螢幕 image number 2
GM34-CWQ2 電競螢幕 image number 3
GM34-CWQ2 電競螢幕 image number 4
GM34-CWQ2 電競螢幕 image number 5
GM34-CWQ2 電競螢幕 image number 6
GM34-CWQ2 電競螢幕 image number 7
GM34-CWQ2 電競螢幕 image number 8
GM34-CWQ2 電競螢幕
GM34-CWQ2 電競螢幕
GM34-CWQ2 電競螢幕
GM34-CWQ2 電競螢幕
GM34-CWQ2 電競螢幕
GM34-CWQ2 電競螢幕
GM34-CWQ2 電競螢幕
GM34-CWQ2 電競螢幕
GM34-CWQ2 電競螢幕
一同潛入遊戲世界
GM34-CWQ2 電競螢幕
GM34-CWQ2 通過精心打造,迎合廣泛喜好,提供更好的價值和性能。擁有 UWQHD 解析度和量子點技術,並且提供廣色域的 DCI-P3 色彩和180Hz 刷新率,更加豐富您的工作和娛樂體驗。
Dive Into The Gaming World
The GM34-CWQ2 is meticulously crafted for universal appeal, delivering exceptional value and performance. With its UWQHD resolution and a Quantum Dot panel, it enriches your work and play experiences by offering a wide DCI-P3 color gamut, all seamlessly displayed at a remarkable 180Hz refresh rate.
Resolution
GREATER IMMERSION
UWQHD resolution (GM34) offers extra screen-real estate for
increased multi-tasking efficiency and much more immersive content
and gaming. Feature 1500R Curvature which is also the sweet spot for
immersion. Having a more pronounced curvature can start to increase
distortion at certain points of the screen and generally harmful to
content creation applications. With the 1500R curvature, games and
entertainment content are even more immersive, spreading around
you and making you feel more part of the action.
Fluid Visuals
ULTRA- SMOOTH REALISM
FreeSync Premium ensures smooth, lifelike gameplay that accurately reproduces a level of realism to everything you play. By synchronizing the frames outputted from the GPU to the refresh rate of the monitor, you can experience tear-free gameplay that is smoother than ever.
Screen
Fluid
gaming experience
Colors
95% DCI-P3 AND 6-AXIS COLOR ADJUSTMENT
Incredible color detail wide color gamut, GM34-CWQ2 comes equipped with Quantum Dot displays that cover 95% of DCI-P3 respectively making these monitors great for color-sensitive work.
EASY ON THE EYES
Protect your eyes from potentially harmful blue light and ensure prolonged comfort with Low Blue Light and Flicker-Free technologies, minimizing eye strain for extended work or gaming.
Ports & Slots
Connectivity Options
Vivid Colors
4000:1 Contrast & HDR400
Revolutionize your visual experience.
GM34-CWQ2 is equipped with VA panels
which have the benefit of much darker
and deeper blacks, leading to an enhanced
4000:1 contrast ratio. Standard IPS monitors
have a contrast ratio of 1000:1 on average.
Picture in picture (PIP) &  Picture by picture (PBP)
Multitasking
Enhance your productivity, work, chat and play with PBP technology. Seamlessly switch between dual sources at their native resolutions to analyze two projects or run two programs concurrently. Leverage PIP functionality to receive a secondary source, enabling efficient multitasking with ease.
Built-in Dual Speakers
Audio
Experience sound entertainment with 2 built-in speakers no need for extra peripherals. Save desk space and streamline your setup for efficient work, learning, and play.
  • 產品型號 CMI-GM34-CWQ2
  • 面板類型 曲面系列
  • 曲率 1500R
  • 長寬比 21:9
  • 螢幕尺寸 34"
  • 面板 VA 10bit (8bit+FRC) w/ Quantum Dot
  • 解析度 UWQHD 3440x1440
  • 更新率 165 Hz (普通), 180 Hz (超載)
  • 對比度 4000:1
  • 可視角度 (H/V) 178°/178°
  • 亮度 320 nits
  • HDR400 相容
  • 色域 DCI-P3 95%
  • 介面 (輸入/輸出) - DP 1.4 1
  • 介面 (輸入/輸出) - HDMI 2.0 2
  • 介面 (輸入/輸出) - USB Type C 1 (PD 65W + DP ALT)
  • 介面 (輸入/輸出) - USB 3.0 Type B 1
  • 介面 (輸入/輸出) - USB 3.0 Type A 2
  • 介面 (輸入/輸出) - 耳機輸出 1
  • 介面 (輸入/輸出) - 喇叭 2 (5W)
  • DCR (Dynamic Contrast Ratio) 動態對比 支援
  • 超載 支援
  • VRR 技術 FreeSync Premium, FreeSync Range: Yes, G-Sync Range: Yes
  • 反應時間 0.5ms (MPRT), 2ms (GtG)
  • 護眼功能 低藍光
  • 不閃屏 支援
  • KVM 支援
  • PIP/PBP (畫面分割) 支援
  • 功耗 158W (最大值)*
  • VESA 100x100 mm
  • 高度調整範圍 0-80 mm
  • 旋轉調整範圍 -15°~+15°
  • 傾仰調整範圍 -5°~+15°
  • 產品分類 電競螢幕
  • 螢幕系列 GM系列
  • 說明 * 在沒有音源/USB/讀卡器連接的情況下,測量亮度為200 nits 的螢幕。
  • Panel Type VA
