GM25FP image number 0
GM25FP image number 1
GM25FP image number 2
GM25FP image number 3
GM25FP image number 4
GM25FP image number 5
GM25FP
GM25FP
GM25FP
GM25FP
GM25FP
GM25FP
Seamless Fusion of Everyday Work and Play
GM25FP
Introducing the GM25FP, a new monitor designed
with high-octane gamers in mind, but suitable for
office workers and casual entertainment as well.
With features such as a 180Hz refresh rate, an IPS
panel and 106% sRGB color, several display modes suited for a variety of activities, and both a low blue light mode and flicker-free functionality.
The GM25FP will take your game life and work life
to the next level.
For Gamers and Workers Alike
While the GM25FP has been designed to support next-gen gaming, workers and more casual users will also benefit greatly from its features, such as the many visual modes including Act, FPS, RTS, User, Standard, Web, Text, and HDR. Adaptive Sync is also supported for smooth, tear-free visuals to ensure every user's experience is silky and uninterrupted.
Experience Better Gaming Sessions
The Adaptive Sync feature ensures smooth visuals, even when the frame rate fluctuates.
Comfort Day and Night
A Low Blue Light display mode and flicker-free function ensure the GM25FP remains easy on the eyes, even during extra long sessions.
MULTIPLE CONNECTIONS
Connect your devices with I/O ports consisting of:
• HDMI 2.0 x2
• DisplayPort 1.4 x2
• Power
• Audio Out
  • 產品型號 CMI-GM25FP
  • 螢幕尺寸 24.5"
  • 長寬比 16:9
  • 面板類型 平面系列
  • 面板 IPS 16.7M (8 Bit)
  • 解析度 FHD 1920x1080
  • 更新率 180 Hz
  • 對比度 1000:1
  • 可視角度 (H/V) 178°/178°
  • HDR Peak 亮度 250 nits (Typ.)
  • 調光分區 N/A
  • 色域 sRGB 106% (Typ., CIE 1931), DCI-P3 78% (Typ., CIE 1976), Adobe RGB 74% (Typ., CIE 1931)
  • 介面 (輸入/輸出) - DP 1.4 1
  • 介面 (輸入/輸出) - HDMI 2.0 2
  • 介面 (輸入/輸出) - 3.5mm 音源輸出 1
  • DCR (Dynamic Contrast Ratio) 動態對比 支援
  • 超載 支援
  • VRR 技術 Adaptive Sync
  • 反應時間 1ms (MPRT), 1ms (GtG)
  • 護眼功能 低藍光 (S/W)
  • 不閃屏 支援
  • 介面 (輸入/輸出) - 喇叭 N/A
  • KVM N/A
  • PIP/PBP (畫面分割) N/A
  • 燈光 N/A
  • 功耗 24W (Max)
  • VESA 100x100 mm
  • 傾仰調整範圍 -5°~+17°
  • 旋轉調整範圍 N/A
  • 高度調整範圍 N/A
  • 支架調整範圍 N/A
  • Cooler Master 散熱設計 N/A
  • 產品分類 電競螢幕
  • 螢幕系列 GM系列
  • Panel Type IPS
