GA25FC image number 0
GA25FC image number 1
GA25FC image number 2
GA25FC image number 3
GA25FC image number 4
GA25FC
GA25FC
GA25FC
GA25FC
GA25FC
Your Gateway to Productivity and Play
GA25FC
The GA25FC is tailored for both office workers and gamers seeking a seamless and enhanced daily experience. Featuring a 24.5” FHD display and a 120Hz refresh rate, the GA25FC caters to the demands of light esports and everyday tasks alike. It stands as the ideal option for an entry-level display delivering high-value performance.
Your Versatile Solution
The GA25FC is crafted to serve as a versatile essential in your everyday routine, whether for gaming, work, or entertainment. It provides a variety of modes including Act, FPS, RTS, User, Standard, Web, Text, and Movie. Adaptive Sync is also supported for smooth and tear-free visuals. These numerous options provide users of all kinds with the flexibility they need to get anything done.
Fast and Seamless
Fast and Seamless
With a 120Hz refresh rate and 1ms (MPRT) response time, winning any game is within your reach, while other activities as such as working or movie-watching will see less motion blur and smearing.
Experience Better Gaming Sessions
The Adaptive Sync feature ensures smooth visuals, even when the frame rate fluctuates.
A Vivid Visual Experience
With a IPS panel, 1500:1 contrast ratio, and 105% sRGB color, the GA25FC provides a more colorful and realistic image, which ensures an elevated visual experience.
All-Day Comfort
The Low Blue Light Display mode reduces the amount of potentially harmful blue light, while the Flicker-Free function provides a stable display, putting your mind at ease during long sessions.
CONVENIENT CONNECTIVITY
Connect your devices with I/O ports consisting of:
• HDMI 1.4
• VGA
• Power
  • 產品型號 CMI-GA25FC
  • 螢幕尺寸 24.5"
  • 長寬比 16:9
  • 面板類型 平面系列
  • 面板 IPS 16.7M (6 bit + FRC)
  • 解析度 FHD 1920x1080
  • 更新率 120 Hz
  • 對比度 1000:1
  • 可視角度 (H/V) 178°/178°
  • 亮度 250 nits (Typical)
  • HDR N/A
  • HDR Peak 亮度 N/A
  • 調光分區 N/A
  • 色域 sRGB 105% (Typ., CIE 1931)
  • 介面 (輸入/輸出) - VGA 1
  • 介面 (輸入/輸出) - HDMI 1.4 1
  • DCR (Dynamic Contrast Ratio) 動態對比 支援
  • 超載 支援
  • VRR 技術 Adaptive Sync
  • 反應時間 1ms (MPRT), 4ms (GtG)
  • 護眼功能 低藍光 (S/W)
  • 不閃屏 N/A
  • 介面 (輸入/輸出) - 喇叭 N/A
  • KVM N/A
  • PIP/PBP (畫面分割) N/A
  • 功耗 24W (Max)
  • VESA 100x100 mm
  • 傾仰調整範圍 -5°~+20°
  • 旋轉調整範圍 N/A
  • 高度調整範圍 N/A
  • 支架調整範圍 N/A
  • Cooler Master 散熱設計 N/A
  • 產品分類 電競螢幕
  • 螢幕系列 GA系列
  • 面板類型 平面系列
