Exceptional Efficiency
The G Gold V2 is certified to achieve more than 90% efficiency at typical loads.
*All performance stats confirmed in 25°C ambient temperature testing.![]()
Power Evolved
G Gold V2, the upgraded version of the G Gold featuring ATX 3.1 support, high temperature resilience and 80 Plus Gold efficiency.
Compliant with ATX 3.1 to fully support a peak power 1.5 times higher than the rated maximum wattage, this unit is ideal for use with the 40 series GPUs.
An embossed cable texture provides a softer and overall improved grip with a pleasing aesthetic.
A hydrodynamic bearing fan delivers long-lasting quiet and effective cooling.
A 40°C operating temperature allows for pushing your machine to the limits.
