Global Headquarters
簡單但功能強大
Notepal ERGOSTAND IV 是一款人體工學筆記型散熱墊,能讓您重拾使用筆記型電腦的樂趣。一顆符合空氣力學的 140mm 靜音風扇,讓您的筆記型電腦涼快且流暢的運作。5 段人體工學高度設定,提供舒適的視角。全網孔底板的導入,能大幅度提高散熱效能。
The Notepal ERGOSTAND IV is an ergonomic laptop cooling stand that will make using your laptop fun again. A 140mm silent fan with aerodynamic design keeps your laptop cool and working smoothly. 5 ergonomic height settings for comfortable viewing angles. The use of full mesh board improves its cooling performance greatly. A blue LED strip gives you the edge in the dark and 4 additional USB ports let you plug in all your devices.
5 ergonomic height settings make sure you are always able to choose the right height for your viewing angle.
A blue LED strip helps you find the right keys on your keyboard and 4 additional USB ports give you all the flexibility to connect your devices.
A 140mm fan, designed for silence, keeps you laptop cool and working smoothly.
