ERGO L 人體工學椅 image number 0
ERGO L 人體工學椅 image number 1
ERGO L 人體工學椅 image number 2
ERGO L 人體工學椅 image number 3
ERGO L 人體工學椅 image number 4
ERGO L 人體工學椅 image number 5
ERGO L 人體工學椅 image number 6
ERGO L 人體工學椅 image number 7
ERGO L 人體工學椅 image number 8
ERGO L 人體工學椅 image number 9
ERGO L 人體工學椅 image number 10
ERGO L 人體工學椅 image number 11
ERGO L 人體工學椅 image number 12
ERGO L 人體工學椅 image number 13
ERGO L 人體工學椅 image number 14
ERGO L 人體工學椅 image number 15
ERGO L 人體工學椅 image number 16
ERGO L 人體工學椅 image number 17
ERGO L 人體工學椅 image number 18
ERGO L 人體工學椅 image number 19
ERGO L 人體工學椅 image number 20
ERGO L 人體工學椅 image number 21
ERGO L 人體工學椅
ERGO L 人體工學椅
ERGO L 人體工學椅
ERGO L 人體工學椅
ERGO L 人體工學椅
ERGO L 人體工學椅
ERGO L 人體工學椅
ERGO L 人體工學椅
ERGO L 人體工學椅
ERGO L 人體工學椅
ERGO L 人體工學椅
ERGO L 人體工學椅
ERGO L 人體工學椅
ERGO L 人體工學椅
ERGO L 人體工學椅
ERGO L 人體工學椅
ERGO L 人體工學椅
ERGO L 人體工學椅
ERGO L 人體工學椅
ERGO L 人體工學椅
ERGO L 人體工學椅
ERGO L 人體工學椅
玩遊戲,也像個老大一般
ERGO L 人體工學椅
Cooler Master ERGO L 的設計目的在於提供終極舒適度,增強您的整體坐姿。 憑藉符合人體工程學的設計和超耐用的全鋁背框支撐,它會是您全天工作或遊戲的完美選擇。 您可以掌控自己的命運,與 ERGO L 一同贏得競賽。指揮您的軍隊,挑戰您的對手,打造您的角色並征服一切。
立即購買
Work & Play Never Stops
Say yes to a chair that can take on any number of hours in front of your screen, be it for productivity or gaming. Build for utmost comfort, our Cooler Master Ergo Chair bridges the gap between performance looks and seated well-being for the champions that give their all every day. Better cooling and improved ventilation for longer sessions is provided by the breathable MuscleFlex® high tension mesh that also creates a unique suspended seating comfort with less fatigue and pressure. Get ready for work & play’s next level!
Designed for Comfort and Cooling Performance
Cast Aluminium Strength
Ergo L sports a 3D-engineered Cast Aluminium frame that synchronizes armrest with seatback reclining in a unibody design. This lightweight material doesn’t just look pristine but offers hours on hours of consistent performance and durability.
Hard Frame, Soft Core
The Ergo mesh seat and backrest undergo rigorous testing with over 20.000 cycles of abrasion, load and tensile tests. It’s rigid yet soft, subtle but powerful, the perfect companion for those who desires to be at the top of their game.
Effortless Personalization
Mesh Me Up!
Mesh Me Up!
Breathable MuscleFlex® high tension mesh is a ballistic-like material that strikes the perfect balance between strength and elasticity whilst providing uncompromised tenderness for all body shapes and weights! Tested at 100,000 cycles against impact and Technical Bulletin 117-2013 Smolder Resistance, the Cooler Master Ergo L can take a serious beating and still come out victorious. Like player, like chair.
  • 產品型號 CMI-GCEL-2019
  • 顏色 黑色
  • 整體高度範圍 120-134 cm
  • 椅背高度 72-77.5cm / 28.3"-30.5" (包含頭枕)
  • 靠背寬度 40-50 cm
  • 扶手到扶手寬度 69 cm
  • 椅子深度 51cm / 20.1"
  • 座椅寬度 (含側邊) 51 cm
  • 座椅深度 45-49 cm (可調整)
  • 本體直徑 70 cm
  • 扶手可調範圍 24-28 cm
  • 地板至椅墊高度 48-56.5 cm
  • 高度可調範圍 8.5 cm
  • 座椅深度調整範圍 4cm / 1.6"
  • 可調後仰角度 90-120 度
  • 扶手 2D (抬高, 向前)
  • 頭枕 可調 (升降, 傾斜)
  • 內部用料 高張力網布
  • 框體材質
  • 底座材質
  • 滾輪 75 mm
  • 氣壓棒 Class 4
  • 淨重 27.8 kg
  • 毛重 33.4 kg
  • 最大負重 200 kg
  • 產品保固 2 年
  • 產品分類 電競椅
  • 電競椅系列 人體工學系列
