ELITE NEX PN500 Peak | Accesible but reliable ATX PSU image number 0
ELITE NEX PN500 Peak | Accesible but reliable ATX PSU image number 1
ELITE NEX PN500 Peak | Accesible but reliable ATX PSU image number 2
ELITE NEX PN500 Peak | Accesible but reliable ATX PSU image number 3
ELITE NEX PN500 Peak | Accesible but reliable ATX PSU image number 4
ELITE NEX PN500 Peak | Accesible but reliable ATX PSU image number 5
NEX Level Power
The ELITE NEX Peak is an entry-level, reliable PSU. The quiet 120mm fan, active power factor correction, exceptional temperature resistance
High Peak Power Tolerance
75% Efficiency and Durable Reliability
  • 型號 MPW-5001-ACAK-P
  • ATX 版本 ATX 12V Ver. 2.41
  • 功率因數校正 主動式 PFC
  • 輸入電壓 100-240V
  • 輸入電流 6A
  • 輸入頻率 47-63Hz
  • 風扇尺寸 120mm
  • 風扇軸承 油封軸承
  • 轉換效率 ≥ 75% @ Typical Load
  • ErP 2014 Lot 3 符合
  • 工作溫度 0-40°C
  • 電源良好信號 100 - 500 ms
  • 持續輸出時間 ≥10ms (100% 負載)
  • 平均故障間隔 (MTBF) >100,000 小時
  • 保護機制 OVP / OPP / UVP / OTP / SCP / Surge & Inrush Protection
  • 安規 TUV, cTUVus, CE, FCC, BSMI, CCC, EAC, UKCA
  • ATX 24 Pin 電源接頭 1
  • EPS 4+4 Pin 電源接頭 1
  • PCI-e 6+2 Pin 電源接頭 1
  • SATA & Peripheral 4 Pin Connectors 6
  • 產品系列 Elite 系列
  • 分類 500-750瓦
  • 模組化 無模組化
  • 80 Plus 無 80 PLUS
  • Watts 500W
