Dyn X Accessories image number 0
Dyn X Accessories image number 1
Dyn X Accessories image number 2
Dyn X Accessories image number 3
Dyn X Accessories image number 4
Dyn X Accessories
Dyn X Accessories
Dyn X Accessories
Dyn X Accessories
Dyn X Accessories
Dyn X Accessories
Dyn X Motion System
Introducing the Cooler Master Dyn X Motion System: a leap forward in motion simulation, designed for sim racing, and flight simulation enthusiasts and professionals. With larger motors and actuators, our motion system supports more weight and delivers a powerful, torque-enhanced feel, making it ideal for commercial applications. As a highly reliable, industrial-grade system, it offers exceptionally realistic vehicle motion feedback through advanced signal processing. Experience every elevation change, vehicle movement, surface change, and gear shift with unparalleled fidelity.
Dyn X Motion System
Dyn X Motion System
Professional Motion System
Provides exceptionally realistic vehicle motion feedback.
DYN X ACTUATOR MOUNT FEATURES
Broad Compatibility
Haptic Feedback
Electronic Mounting Tray
Simple And Easy Installation
Responsive actuator travel
Features 2” (50mm) of possible travel.
Rugged Construction
A piston featuring an especially large diameter and a machined billet with aluminum housing have been built to last.
Large weight capacity
Supports up to 800 lbs. (363 kg).
Cooler Master x  Simucube 2 Pro Co-brand Direct Drive Wheelbase
The Cooler Master x Simucube 2 Pro Co-brand Direct Drive Wheelbase represents a new cutting-edge advancement in sim racing gear designed for elite racers and dedicated enthusiasts. The Cooler Master x Simucube 2 Pro Wheelbase revolutionizes the racing simulation experience with its unparalleled precision and immersive force feedback, driven by a high-torque, brushless motor. Engineered for excellence, this wheelbase redefines expectations, offering an unmatched level of realism and engagement in the virtual racing world.
Dyn X Actuator Mount
Broad Compatibility
Works with most available actuators including Cooler Master, Sigma Integrale, D-BOX, and Qubic System.
Haptic Feedback
The Dyn X and actuator mounts were developed together to effectively provide immersive haptic feedback.
Includes a mounting tray for use with most available actuator controller boxes, such as those listed above.
Both the actuator mounts and the electronic mounting tray quickly bolt onto the Dyn X frame.
Dyn X Cockpit Monitor Mount​
Wide Range Of Compatibility
Compatible with monitors with VESA 75x75mm or VESA 100x100mm, majority of monitors in the market.
Supports up to single 49” ultra wide (32:9) monitor.
Seamless Integration
Single monitor stand that can be directly installed and integrated with the Dyn X cockpit.
Works with Dyn X at any driving position it can simulate.
Dyn X Shifter & Handbrake Mount​
Compatible with multiple shifter and handbrake brands and models, as well as flight simulators’ stick and throttle.
Flexible Adjustment
Mounts can be adjusted to user’s favorite position and installed on either side of Dyn X, supporting both right-handed and left-handed users.
Tough Durability
Made for a durable, solid steel
Dyn X Flight Mount Upgrade Kit
Flexible Adjustment
Tough Durability
Dyn X Steering Mount Adapter
Add support for many more models of front mount wheelbases.
High Durability
Durable as expected from Dyn X professional sim racing cockpit.
Dyn X Steering Side Mount
Personalized Adjustment
Multi-adjustable design allows you to experience the most realistic yet comfortable driving position.
Quality Build
Solid structure and thick-walled carbon steel enables you to conquer every curve without compromise.
Dyn X Steering Tray Mount
Quality Build
Dyn X Quick Release
Dyn X Quick Release
Seat Adjustment
A simple and tool-less seat adjustment solution in addition to the seat slider allows for customization without sacrificing haptic feedback.
High Durability
Comes with a tough, stainless-steel handle capable of withstanding applied pressure.
Dyn X Speaker Mount
Dyn X Speaker Mount
Flexible Adjustment
360-degree adjustable design allows for ultimate flexibility
High Build Quality
An Aluminum Alloy and Stainless Steel build allow for long hours of use.
