Dyn X Cockpit Monitor Mount​ image number 0
Dyn X Cockpit Monitor Mount​ image number 1
Dyn X Cockpit Monitor Mount​ image number 2
Dyn X Cockpit Monitor Mount​ image number 3
Dyn X Cockpit Monitor Mount​ image number 4
Dyn X Cockpit Monitor Mount​ image number 5
Dyn X Cockpit Monitor Mount​ image number 6
Wide Range Of Compatibility
Compatible with monitors with VESA 75x75mm or VESA 100x100mm, majority of monitors in the market.
Supports up to single 49” ultra wide (32:9) monitor.
Seamless Integration
Single monitor stand that can be directly installed and integrated with the Dyn X cockpit.
Works with Dyn X at any driving position it can simulate.
