COSMOS C700M Full Tower PC Case image number 0
COSMOS C700M Full Tower PC Case image number 1
COSMOS C700M Full Tower PC Case image number 2
COSMOS C700M Full Tower PC Case image number 3
COSMOS C700M Full Tower PC Case image number 4
COSMOS C700M Full Tower PC Case image number 5
COSMOS C700M Full Tower PC Case image number 6
COSMOS C700M Full Tower PC Case image number 7
COSMOS C700M Full Tower PC Case image number 8
COSMOS C700M Full Tower PC Case image number 9
COSMOS C700M Full Tower PC Case image number 10
COSMOS C700M Full Tower PC Case image number 11
COSMOS C700M Full Tower PC Case image number 12
COSMOS C700M Full Tower PC Case image number 13
COSMOS C700M Full Tower PC Case image number 14
COSMOS C700M Full Tower PC Case image number 15
COSMOS C700M Full Tower PC Case image number 16
COSMOS C700M Full Tower PC Case image number 17
COSMOS C700M Full Tower PC Case image number 18
COSMOS C700M Full Tower PC Case image number 19
COSMOS C700M Full Tower PC Case image number 20
COSMOS C700M Full Tower PC Case image number 21
COSMOS C700M Full Tower PC Case image number 22
COSMOS C700M Full Tower PC Case image number 23
COSMOS C700M Full Tower PC Case image number 24
COSMOS C700M Full Tower PC Case image number 25
重新定義標準
The COSMOS series is known for pushing the limits of Cooler Master's case technology
顏色
立即購買
Design
HIGHLY VERSATILE LAYOUT
The unique frame design supports a conventional, chimney, inverse layout, or a fully customized layout. Each part of the frame enables a high level of versatility. From multi-functional brackets to options in component positioning, the COSMOS C700M encourages freedom in building and out-of-the-box customizability.
Design
EXTENSIVE CABLE COVER SYSTEM
The 3 included covers can be placed on either the M. Port or on the mid-plate, with the ability to mount SSD storage or a reservoir.
Our Achievements
6 awards
Design
graphics card mounting with riser cable
The graphics card bracket can be mounted vertically or horizontally on either the PSU midplate or on the M. Port. The bracket can also be rotated from 0 to 90 degrees.
Also included is a 400mm riser cable for the convenience of being able to connect a vertically mounted graphics card to the motherboard.
Rich Connectivity
Ports & Slots
Rich Connectivity
The advanced I/O panel comes with a 4-Pole headset jack (audio+mic), dedicated mic jack, USB 3.1 (Gen 2) Type-C port, four additional USB 3.0 ports, PWM fan speed button, and an addressable RGB control button.
ALUMINUM PANELS & HANDLES
Brushed aluminum spans the top panel and front panel, with cast aluminum handles (and feet) that provide protection & support for carrying the case.
ADDRESSABLE RGB LIGHTING
Two parallel strips of addressable RGB lighting run continuously from the top panel to the front panel, with ambient ARGB lighting on the bottom that reflects against the aluminum bars.
VERSATILE LIQUID COOLING SUPPORT
A flat radiator bracket design offers more versatility for liquid cooling with the ability to be mounted on the top, front, or bottom of the frame. The two included brackets can each support a 420mm radiator, with the ability to mount fans and a radiator on either side of the bracket.
CURVED TEMPERED GLASS SIDE PANEL
A panoramic tempered glass side panel, with two curved edges, offer
a wide view of the system build.
  • 產品型號 MCC-C700M-MG5N-S00, MCC-C700M-WG5N-S00
  • 顏色 Grey, Silver & Black (MCC-C700M-MG5N-S00), Silver & White (MCC-C700M-WG5N-S00)
  • 材質 - 機身 金屬
  • 材質 - 側板 Curved Tempered Glass, Steel
  • 尺寸 (長x寬x高) 650 x 306 x 651mm
  • 主機板支援 Mini-ITX, Micro-ATX, ATX, E-ATX (support up to 12" x 10.7")
  • PCI 擴充槽 8
  • 5.25" 硬碟架 1
  • 2.5"/3.5" 硬碟架 (複合式) 4+1 (於配件包內)
  • 硬碟架 - SSD 4
  • I/O 面板 - USB 插槽 / USB 3.1 Type-C 1
  • I/O 面板 - USB 插槽 / USB 3.0 Type-A 4
  • I/O 面板 - 音訊 - 3.5mm 耳機麥克風插槽 (音效+麥克風) 1
  • I/O 面板 - 音訊 - 3.5mm 麥克風插槽 1
  • I/O 面板 - 風扇/燈效開關 Fan Speed Control Button, ARGB Control Button
  • 預裝風扇 - 前方 3x 140mm PWM 風扇 (轉速: 1200RPM / 連接介面: 4Pin)
  • 預裝風扇 - 後方 1x 140mm PWM 風扇(轉速: 1200RPM / 連接介面: 4Pin)
  • 風扇支援 - 上方 3x 120/140mm
  • 風扇支援 - 前方 3x 120/140mm
  • 風扇支援 - 後方 1x 120/140mm
  • 風扇支援 - 底部 2x 120/140mm (需搭配支架)
  • 水冷支援 - 上方 120mm, 140mm, 240mm, 280mm, 360mm, 420mm (remove ODD, maximum thickness clearance 70mm)
  • 水冷支援 - 前方 120mm, 140mm, 240mm, 280mm, 360mm, 420mm (remove ODD)
  • 水冷支援 - 後方 120mm, 140mm
  • 水冷支援 - 底部 120mm, 140mm, 240mm
  • 預留安裝空間 - CPU 散熱器 198mm
  • 預留安裝空間 - 顯示卡 490mm (移除 3.5" 硬碟架), 320mm (安裝 3.5" 硬碟架)
  • 配件 Riser Cable PCIe 4.0 x16 - 400mm (向下相容 PCI Express 4.0 Gen 3)
  • 尺寸 高直立式
  • 系列 COSMOS 系列
  • Product Sheet - COSMOS C700M (Riser Cable PCIe 3.0 SN Before MCCC700MMG5NS001214200001) Download
  • Product Sheet - COSMOS C700M & C700M White Download
  • Manual Download
