Caliber R1S CAMO 電競椅 image number 0
Caliber R1S CAMO 電競椅 image number 1
Caliber R1S CAMO 電競椅 image number 2
Caliber R1S CAMO 電競椅 image number 3
Caliber R1S CAMO 電競椅 image number 4
Caliber R1S CAMO 電競椅 image number 5
Caliber R1S CAMO 電競椅 image number 6
Caliber R1S CAMO 電競椅 image number 7
Caliber R1S CAMO 電競椅 image number 8
Caliber R1S CAMO 電競椅 image number 9
Caliber R1S CAMO 電競椅 image number 10
Caliber R1S CAMO 電競椅 image number 11
Caliber R1S CAMO 電競椅 image number 12
Caliber R1S CAMO 電競椅 image number 13
Caliber R1S CAMO 電競椅 image number 14
Caliber R1S CAMO 電競椅 image number 15
Caliber R1S CAMO 電競椅 image number 16
Caliber R1S CAMO 電競椅 image number 17
Caliber R1S CAMO 電競椅 image number 18
Caliber R1S CAMO 電競椅 image number 19
Caliber R1S CAMO 電競椅 image number 20
Caliber R1S CAMO 電競椅 image number 21
Caliber R1S CAMO 電競椅 image number 22
Caliber R1S CAMO 電競椅 image number 23
Caliber R1S CAMO 電競椅 image number 24
Caliber R1S CAMO 電競椅 image number 25
Caliber R1S CAMO 電競椅 image number 26
Caliber R1S CAMO 電競椅 image number 27
Caliber R1S CAMO 電競椅 image number 28
Caliber R1S CAMO 電競椅 image number 29
Caliber R1S CAMO 電競椅 image number 30
Caliber R1S CAMO 電競椅 image number 31
Caliber R1S CAMO 電競椅 image number 32
Caliber R1S CAMO 電競椅 image number 33
Caliber R1S CAMO 電競椅 image number 34
Caliber R1S CAMO 電競椅 image number 35
Caliber R1S CAMO 電競椅 image number 36
Caliber R1S CAMO 電競椅 image number 37
Caliber R1S CAMO 電競椅 image number 38
Caliber R1S CAMO 電競椅 image number 39
Caliber R1S CAMO 電競椅 image number 40
Caliber R1S CAMO 電競椅 image number 41
Caliber R1S CAMO 電競椅 image number 42
Caliber R1S CAMO 電競椅 image number 43
Caliber R1S CAMO 電競椅 image number 44
Caliber R1S CAMO 電競椅 image number 45
Caliber R1S CAMO 電競椅 image number 46
Caliber R1S CAMO 電競椅 image number 47
戰備升級
Gain more XP, no more muscle stiffness! With an ergonomic design and premium PU material, Caliber R1S is your perfect match for long hours of missions
顏色
立即購買
  • 產品型號 CMI-GCR1S-PRC, CMI-GCR1S-BKC, CMI-GCR1S-PKC
  • 顏色 CM CAMO, Dark Knight CAMO, SAKURA CAMO
  • 整體高度範圍 125-133 cm / 49.2"-52.4"
  • 椅背高度 82 cm / 32.3"
  • 靠背寬度 57 cm / 22.4"
  • 扶手到扶手寬�� 75 cm / 29.5"
  • 座椅寬度 (含側邊) 53 cm / 20.9"
  • 可坐範圍 37 cm / 14.5"
  • 座椅深度 57 cm / 22.4"
  • 本體直徑 70 cm / 27.6"
  • 鋼板厚度 1.2 mm
  • 扶手可調範圍 28-36 cm / 11.0"-14.2"
  • 地板至椅墊高度 45-53 cm / 17.7"-20.9"
  • 高度可調範圍 8 cm / 3.1"
  • 可調後仰角度 90-180 degree
  • 扶手 1D, 2D (Rose White)
  • 頭枕 Ergonomic Pillow
  • 腰部支援 Ergonomic
  • 外部用料 Perforated PU
  • 內部用料 Backrest: cut foam, Seatbase: cold molded foam
  • 框體材質 Steel
  • 底座材質 (腳) Nylon
  • 滾輪 60 mm / 2.4"
  • 氣壓棒 Class 4
  • 淨重 21.5 kg / 47.4 lbs
  • 毛重 24 kg / 52.9 lbs
  • 最大負重 150 kg / 330 lbs
  • 產品保固 1 year
  • 產品分類 Gaming Chair
  • 電競椅系列 Caliber R1 Series
