ARGB顯示卡支架 image number 0
ARGB顯示卡支架 image number 1
ARGB顯示卡支架 image number 2
ARGB顯示卡支架 image number 3
ARGB顯示卡支架 image number 4
ARGB顯示卡支架 image number 5
ARGB顯示卡支架
ARGB顯示卡支架
ARGB顯示卡支架
ARGB顯示卡支架
ARGB顯示卡支架
ARGB顯示卡支架
讓您的顯示卡更穩固
ARGB顯示卡支架
MasterAccessoryARGB顯示卡支架不論在功能性或者美觀度都能帶給您同等的震撼,不但讓PCI-e插槽更加安全穩固,驚豔的外觀設計更是讓人忍不住多看一眼。
立即購買
A New Type of Reinforcement
Tempered glass, addressable RGB, and edge-lighting technology all crammed into a not-so-simple graphics card support bracket.  Sure, GPU brackets are an important tool in keeping your motherboard’s PCI-e slot safe from sag but we bet you didn’t expect it to be the new centerpiece to your build.
The MasterAccessory ARGB GPU Support Bracket utilizes the strength and aesthetic of tempered glass in completely new ways. The strength of the TG supports the biggest, baddest cards out there. The CNC machining provides edge-lit ARGB. The universal design of the support arm offers hassle-free adjustment, by sliding and locking in place, to fit a high range of graphics card and PC case combinations. If your build is on the subtler side, switch off the lighting for an elegant, invisible GPU support bracket.
Equal parts functional and artistic, the MasterAccessory ARGB GPU Support Bracket keeps your PCI-e slots safe as effectively as it keeps you staring at your glorious build for way too long.
Eliminate Graphics Card Sag
As graphics cards become larger and heavier, PCI-e slots suffer from increased stress and weight. The MasterAccessory ARGB GPU Support Bracket eliminates this by supporting the GPU’s weight-critical points.
Easy to Install
Edge-lit ARGB Tempered Glass
CNC machining on the tempered glass creates rails for ARGB lighting to travel throughout the bracket. The lighting can also be turned off for a near-invisible aesthetic.
Multiple Orientations
Protect Your Components
Versatile Support
  • 產品型號 MCA-U000R-GSBTG-00
  • 顏色 黑
  • 材質 - 外部 ABS Plastic, Tempered Glass
  • 尺寸 (長x寬x高) 58 x 58 x 177mm (包括突起)
  • ARGB線材長度 510mm
  • 內建支援顯卡數 2
  • ARGB 控制器 未含
  • 總重量 0.22 kg / 支
  • 淨重 0.14 kg / 支
  • 保固 2 年
  • 系列 其他系列
