Hyper 212 黑化版 (LGA1700) image number 0
Hyper 212 黑化版 (LGA1700) image number 1
Hyper 212 黑化版 (LGA1700) image number 2
Hyper 212 黑化版 (LGA1700) image number 3
Hyper 212 黑化版 (LGA1700) image number 4
Hyper 212 黑化版 (LGA1700) image number 5
Hyper 212 黑化版 (LGA1700) image number 6
Hyper 212 黑化版 (LGA1700) image number 7
Hyper 212 黑化版 (LGA1700) image number 8
富有傳奇色彩的 Hyper 系列空冷散熱器強勢回歸。Hyper 212 黑化版帶來更好的安裝方法與更強大的散熱能力,是最好的空冷散熱方案之一。鋁質上蓋搭配如噴射機一般的鍍鎳黑色散熱片,讓 Hyper 212 黑化版在外觀上更具質感與吸引力。細緻的黑色塗裝不僅讓他更加好看,同時提升了散熱表現。
Sleek Finish
Sleek Finish
The top cover is brushed, anodized aluminum that is finished in gunmetal black for a refined look.
Precise Air Flow with Nickel Black Fins
Stacked fin arrays ensure the least airflow resistance, which allows cooler air to flow into the heatsink. The nickel plated jet black fins also enhance radiation cooling performance.
Direct Contact Technology
4 heat pipes with exclusive Direct Contact Technology provide effective and excellent heat dissipation.
Silent Technology
The Silencio FP120 features exclusive Silent Driver IC technology which reduces noise and power output. The fan blade design, inspired by helicopters, packs more force into the space in front of the fan.
Optional Push-pull Fan Configuration
An additional fan helps to pull heat away faster from the heatsink to avoid dynamic losses and helps to accelerate heat exhaust.
Universal Mounting Kits Design
The improved universal bracket design ensures easy and worry-free installation on all platforms.
  • 產品型號 RR-212S-20PK-R2
  • 外觀顏色 黑色
  • CPU 腳位 LGA1700, LGA1200, LGA1156, LGA1155, LGA1151, LGA1150, LGA1366, AM5*(see Note), AM4, AM3+, AM3, AM2+, AM2, FM2+, FM2, FM1
  • 尺寸 (長 x 寬 x 高) 123 x 77 x 158.8 mm
  • 散熱器材質 4根熱管 / 直觸 / 鋁製散熱片
  • 風扇數量 1 個
  • 風扇轉速 800-2000 RPM (PWM) ± 10%
  • 風扇風量 42 CFM (最大)
  • 風扇噪音水平 6.5 - 26 dBA
  • 風扇風壓 2.9 mmH2O
  • 風扇平均故障間隔 >160,000 小時
  • 風扇連接介面 4-Pin (PWM)
  • 風扇額定電壓 12 VDC
  • 風扇額定電流 0.08A
  • 風扇安全電流 0.16A
  • 風扇功耗 0.96W
  • *Note AM5 mounting kits are included from a certain point in production. You might receive the cooler without the AM5 bracket. You may obtain the requiered mounting kits for products through the CM store, regional resellers and distributors.
  • 產品保固 2年
  • 系列 Hyper
  • 產品類型 CPU空冷散熱器
  • 熱導管數量 4
