Global Headquarters
自由打造自己的風格
QUBE 500,一款讓您發揮創意隨意打造,突顯個人風格和創意的平板組件機殼。
Flatpack assembly, Fully modular design, Built-in vertical GPU mount, Full-sized specs, pint-sized body, Highly customizable, Multiple macaron color panels, Accessory ecosystem.
Features modular panels that simplify and streamline the usual case prep process. Every panel is separately removable for easy maintenance.
Besides the clear eco-benefits, we believe flat-packing will provide a fun and satisfying build experience. Welcome to the future of PC DIY.
The symmetric design allows you to switch the steel panel and the glass panel with each other for a non-transparent build.
An unprecedented level of customizability allows for full creative expression.
Fully express yourself with the multi-color Macaron edition. It includes two sets of extra panels, an extra handlebar, and two accessory hooks. Mix and match the modular panels to create a case that is truly your own.
The side radiator mount has two positions, allowing you to install a 280mm radiator or provide your GPU with extra airflow.
Vertically mount your GPU with the included bracket. You can even adjust the distance from the side panel to maintain good airflow.
The Qube 500 comes with a living accessory ecosystem. A Gem mini cable manager and accessory hook are included, and we have prepared some 3D-printable files for you to create your own accessories.
