Cooler Master G Gold 750 V2 | An every day ATX 3.1 upgrade image number 0
Cooler Master G Gold 750 V2 | An every day ATX 3.1 upgrade image number 1
Power Evolved
G Gold V2, the upgraded version of the G Gold featuring ATX 3.1 support, high temperature resilience and 80 Plus Gold efficiency.
ATX 3.1 Support
Compliant with ATX 3.1 to fully support a peak power 1.5 times higher than the rated maximum wattage, the 750W unit is optimized for ideal compatibility with 40 series GPUs.
Embossed Cable
Quiet HDB Fan​
Exceptional Efficiency
The G Gold V2 is certified to achieve more than 90% efficiency at typical loads.​​
High Temperature Resilience
  • 型號 MPE-7502-ACAAG
  • ATX 版本 ATX 12V Ver. 3.1
  • 功率因數校正 主動式 PFC
  • 輸入電壓 100-240V
  • 輸入電流 10-6A
  • 輸入頻率 50-60Hz
  • 風扇尺寸 120mm
  • 風扇軸承 HDB
  • 轉換效率 典型轉換 ≥90%
  • 80 PLUS 評級 80 PLUS 金牌
  • ErP 2014 Lot 3 符合
  • 工作溫度 0-40°C
  • 電源良好信號 100 - 150 ms
  • 持續輸出時間 >16ms
  • 平均故障間隔 (MTBF) >100,000 小時
  • 保護機制 UVP / OVP / OPP / OTP / SCP / OCP
  • 安規 cTUVus, TUV, CE, FCC, BSMI, CCC, EAC, RCM, UKCA, RoHS2.0 / BIS, KC (Based on region's requests.)
  • ATX 24 Pin 電源接頭 1
  • SATA 電源接頭 6
  • 周邊 4 Pin 電源接頭 3
  • PCI-e 6+2 Pin 電源接頭 4
  • 保固 5 Years
  • 產品系列 G 系列
  • 80 Plus 金牌認證
  • 模組化 無模組化
  • 分類 500-750瓦
  • Watts 750W
