Notepal X150 Spectrum 筆電散熱墊 image number 0
Notepal X150 Spectrum 筆電散熱墊 image number 1
Notepal X150 Spectrum 筆電散熱墊 image number 2
Notepal X150 Spectrum 筆電散熱墊 image number 3
Notepal X150 Spectrum 筆電散熱墊 image number 4
Notepal X150 Spectrum 筆電散熱墊 image number 5
極致高效
Notepal X150 Spectrum 筆電散熱器是一款兼具效能和實用性的新款散熱器,適合攜帶,提供您一個優秀的散熱系統
立即購買
The Notepal X150 Spectrum is Here
Cooler Master's Notepal X150 Spectrum combines performance, looks, and functionality into the perfect cooling pad for your portable system. Built with a metal mesh foundation and ideal elevated incline, it gives you stability as well as maximum airflow for efficient heat dissipation.
Metal Mesh Contact Surface
Metal base provides solid support and breathability to cool your device
Ideal Cooling Engineering
Elevated incline promotes increased ventilation and heat dissipation
Quiet Performance
Impressive 160mm fan cools your system at unnoticeably quiet operation
Vibrant LED
Light up your system with a touch of vibrancy with multicolor LED lighting
  • 產品型號 MNX-SWXB-10NFA-R1
  • 顏色 黑色
  • 材質 Metal Mesh, Plastic, Rubber
  • 尺寸 (長 x 寬 x 高) 386 x 280 x 58 mm / 15.2 x 11.0 x 2.3 inch
  • 風扇尺寸 (長 x 寬 x 高) 160 x 160 x 15 mm / 6.3 x 6.3 x 0.6 inch
  • 風扇轉速 1000 RPM ± 15%
  • 風扇風量 57 CFM
  • 風扇噪音水平 26 dBA
  • 供電 USB 5V DC
  • USB USB 2.0 x 3, Type-C x 1
  • 當前功耗 0.21A
  • 功耗 1.05W
  • 相容性 支援至 17 吋筆記型電腦
  • 產品保固 2年
  • 產品類型 筆電散熱器
  • 系列 Notepal
