SickleFlow Edge 360 ARGB image number 0
SickleFlow Edge 360 ARGB image number 1
SickleFlow Edge 360 ARGB image number 2
SAME LEGEND, SHARPER EDGE
Multi-fan Configuration
Quick Connection
Easy Installation
Hollow Frame Structure
Loop Dynamic Bearing
Addressable RGB Lighting
NEXT GENERATION OF SICKLEFLOW FAN
Cooler Master SickleFlow Edge 360 ARGB is our new addition to the renowned SickleFlow series. This fan features enlarged blades for better cooling and a hollow frame for lightweight durability. A single modular cable simplifies setup, and installation requires only 4 screws. Enjoy customizable ARGB lighting, controllable with MasterCTRL software.
MULTI-FAN CONFIGURATION
A single-frame unit enhances internal airflow, effectively expelling heat and significantly improving cooling efficiency.
QUICK CONNECTION
Uses one modular cable for lighting and power, simplifying management and improving aesthetics.
EASY INSTALLATION
Only 4 screws are needed for a hassle-free installation.
HOLLOW FRAME STRUCTURE
This lightweight yet durable fan module, featuring a hollow design with triangular vents ensures efficient airflow and long-lasting performance without adding bulk to your build.
LOOP DYNAMIC BEARING
Features our loop dynamic bearing, our in-house bearings, preventing dust and oil leakage and enhancing operational stability and lifespan.
ADDRESSABLE RGB LIGHTING
Experience vibrant and personalized lighting effects with addressable RGB, fully controllable through our in-house MasterCTRL software for seamless customization.
Discover MasterCTRL
  • 產品型號 MFX-B2DN-25TP2-R1
  • 外觀顏色 黑色
  • 尺寸 (長 x 寬 x 高) 361 x 122 x 26.5 mm / 14.21 x 4.8 x 1.02 inch
  • 設定檔 Addressable Gen 2 RGB
  • 風扇轉速 690-2500 RPM ± 10%
  • 風扇風量 322.8 m³/h (190 CFM)
  • 風扇壓力 3.54 mmH₂O (Max)
  • 風扇平均故障間隔 >160,000 小時
  • 風扇噪音水平 38.5 dBA (Max)
  • 軸承 循環動態軸承 (Loop Dynamic Bearing, LDB)
  • 風扇連接介面 4-Pin (PWM)
  • 風扇額定電壓 12 VDC
  • 風扇額定電流 0.6A
  • 風扇安全電流 0.8 A
  • 風扇功耗 6 W
  • 產品保固 5年
  • 產品類型 機殼風扇
  • 系列 SickleFlow
  • 風扇LED種類 ARGB
  • 風扇尺寸 360
