Silencio S400 image number 0
Silencio S400 image number 1
Silencio S400 image number 2
Silencio S400 image number 3
Silencio S400 image number 4
Silencio S400 image number 5
Silencio S400 image number 6
Silencio S400 image number 7
Silencio S400 image number 8
Silencio S400 image number 9
Silencio S400 image number 10
Silencio S400 image number 11
Silencio S400 image number 12
Silencio S400 image number 13
Silencio S400 image number 14
Silencio S400 image number 15
Silencio S400 image number 16
Silencio S400 image number 17
Silencio S400 image number 18
Silencio S400 image number 19
Silencio S400 image number 20
Silencio S400
Silencio S400
Silencio S400
Silencio S400
Silencio S400
Silencio S400
Silencio S400
Silencio S400
Silencio S400
Silencio S400
Silencio S400
Silencio S400
Silencio S400
Silencio S400
Silencio S400
Silencio S400
Silencio S400
Silencio S400
Silencio S400
Silencio S400
Silencio S400
靜音系列作
Silencio S400
Silencio 是一款不用向散熱效能妥協的靜音機殼。主機由隔音材料環繞,所有風扇都配有橡膠緩衝墊,上方面板可拆卸的遮罩能夠阻隔噪音。Silencio S400 也同時提供強化玻璃或是帶有隔音材料的金屬側板型號供選擇。對於效能有所要求的平台,可移除上方面板的隔音遮罩增加通風。
Silencio Technology
Sound Dampening Material
Front
Ventilation
The front panel features a recurved vent, directing air in through the front bezel. The curve points downward, taking air in from the bottom, and straightens out to direct air in from either side of the steel front door.
Ventilation
Reversible Steel Door
Silencio Fans
Silencio Fans
Versatile HDD Cage
The HDD cage is (re)movable. The cage can be shifted forward to make room for a longer PSU, backwards for additional radiator space, or completely removed if HDD storage is not needed.
Versatile HDD Cage
Versatile HDD Cage
Motherboard Support
Mini-ITX, Micro-ATX
Cooling Support
Fans
Radiators
Top:
120 / 140mm x 1 Fans
120 / 140mm x 2 Fans (remove ODD cage)
120 / 240* Radiator
*remove ODD cage
Front:
120 / 140 / 240 / 280* Radiator
*may interfere with HDD mounted below ODD bracket
Rear:
120 x 1 Fan
120 x 1 Radiator
Storage Support
5.25” ODD x 1 (ODD version)
3.5” HDD x 4
2.5” SSD x 4
Clearances
CPU Cooler (Steel): 167mm
CPU Cooler (TG): 166mm
Power Supply:
325mm (w/o front radiator & HDD cage)
140mm (HDD cage in backmost position)
Graphics Card: 319mm
  • 產品型號 MCS-S400-KN5N-S00 (Steel), MCS-S400-KG5N-S00 (TG)
  • 顏色 黑
  • 材質 - 機身 Steel, Plastic, Sound Absorbing Material
  • 尺寸 (長x寬x高) 418 x 210 x 408mm (Incl. Protrusions), 403.5 x 210 x 400mm (Excl. Protrusions)
  • 容量 33.9L (不含突起)
  • 主機板支援 Mini-ITX, Micro-ATX
  • PCI 擴充槽 4
  • 5.25" 硬碟架 1
  • 3.5" 硬碟架 4
  • 2.5" 硬碟架 4
  • I/O 面板 - USB 埠 2x USB 3.2 Gen 1 (formerly USB 3.0)
  • I/O 面板 - 音效輸入/輸出 3.5mm 耳麥複合插孔(音訊 + 麥克風)* 1
  • I/O Panel - SD Card Reader Supports SD & MMC Cards
  • 預裝風扇 - 前方 1x 120mm (PWM 800-1400 RPM)
  • 預裝風扇 - 後方 1x 120mm (PWM 800-1400 RPM)
  • 風扇支援 - 前方 2x 120/140mm
  • 風扇支援 - 上方 1x 120mm, 1x 140mm / 2x 120mm, 2x 140mm (remove ODD cage)
  • 風扇支援 - 後方 1x 120mm
  • 水冷支援 - 前方 120 / 140 / 240 / 280mm (remove & reinstall ODD bracket to mount 280mm radiator, may interfere with HDD mounted below ODD bracket)
  • 水冷支援 - 上方 120 / 240mm* (*240mm requires removal of ODD cage)
  • 水冷支援 - 後方 120mm
  • 預留安裝空間 - CPU 散熱器 Steel: 167mm, TG: 166mm
  • 預留安裝空間 - 電源供應器 325mm (w/o front radiator & drive cage), 140mm (HDD cage in backmost position)
  • 預留安裝空間 - 顯示卡 319mm
  • 整線空間 20mm
  • 防塵濾網 前方、上方、底部
  • 電源供應器類型 Bottom Mount, ATX PS2
  • 尺寸 迷你直立式
  • 系列 Silencio 系列
