Open-Air Frame Mode
The MasterFrame 700 stands vertically to best display the components behind its panoramic tempered glass screen. The chassis offers an unmatched level of hardware compatibility, allowing for easy-fitting of oversized components.
打造 無與倫比
MasterFrame 700是一款可高度客製化的開放式機殼,能夠在直立機殼展示以及測試平台兩種模式中隨意變形轉換。整體機殼由三個部位組成,包含兩個側翼、一個主機板平台。而四個特殊設計的轉軸緊密連接側翼以及主機板平台。
Our goal is to provide a limitless experience in hardware support. MasterFrame 700 allows you to mount any motherboard in the consumer market, even going so far as to support 14x14" SSI-EEB motherboards.
Double support for ATX power supplies is available on the back, for systems that need double power supply and to cover every need during extreme overclocking sessions.
Note: If SSI-EEB motherboards are installed, the integrated support for custom watercooling pumps and reservoirs becomes unaccessible. In this case, users are recommended to install pump/reservoirs combos directly to the radiators.
With MasterFrame 700 users are able to install up to 2x 280/360mm radiators in "Open-Air" mode (on the two side wings) and a third 360/420mmradiator while in "Test-Bench" mode, in the proximity of the CPUsocket.
The support for pumps and reservoirs on the right side of the motherboard tray allows to natively mount most of the solutions on the market, maintaining a high level of freedom with regard to the placement.
The oversized panoramic tempered glass offers a greater viewing angle on the components of the system and, together with hardware-centric design of MasterFrame 700, it is the perfect way to showcase high-end components and custom cooling solutions.
The open-air nature of the design provides unrestricted access to fresh air to all components in the system.
The optional fan mounts allow to further guide the airflow path to a specific intake/exhaust direction, thus preventing performance-robbing heat recirculation.
Thanks to its modular design, MasterFrame 700 can lay down horizontally and transform into an ultra-featured premium Test Bench. Cooling and power components are installed out of the way of the motherboard area for interference-free installation of components.
The MasterFrame 700 is designed with customization in mind. The 3-parts frame can be easily disassembled easily for painting, wrapping and other modifications.
