COSMOS C700P 黑化版 image number 0
COSMOS C700P 黑化版 image number 1
COSMOS C700P 黑化版 image number 2
COSMOS C700P 黑化版 image number 3
COSMOS C700P 黑化版 image number 4
COSMOS C700P 黑化版 image number 5
COSMOS C700P 黑化版 image number 6
COSMOS C700P 黑化版 image number 7
COSMOS C700P 黑化版 image number 8
COSMOS C700P 黑化版 image number 9
COSMOS C700P 黑化版 image number 10
COSMOS C700P 黑化版 image number 11
COSMOS C700P 黑化版 image number 12
COSMOS C700P 黑化版 image number 13
COSMOS C700P 黑化版 image number 14
COSMOS C700P 黑化版 image number 15
COSMOS C700P 黑化版
COSMOS C700P 黑化版
COSMOS C700P 黑化版
COSMOS C700P 黑化版
COSMOS C700P 黑化版
COSMOS C700P 黑化版
COSMOS C700P 黑化版
COSMOS C700P 黑化版
COSMOS C700P 黑化版
COSMOS C700P 黑化版
COSMOS C700P 黑化版
COSMOS C700P 黑化版
COSMOS C700P 黑化版
COSMOS C700P 黑化版
COSMOS C700P 黑化版
COSMOS C700P 黑化版
重新定義標準
COSMOS C700P 黑化版
COSMOS C700P 黑化版不單只是導入消光黑塗裝,包括對原版的內部與外部結構改良。電源供應器遮罩、精細網孔面板、線材遮罩系統以及額外的後側面板都將 COSMOS 的模組化基礎推向另一個高度。雖然面板與把手以黑色為主題,但曲面強化玻璃側板比原版帶有更淺的色調。
Expanding the Cosmos
Upgraded Cover System
The PSU Shroud advances in modularity with two independent parts while the cable cover system features 3 separate pieces, each with the capability of mounting storage or a pump for liquid cooling.
Flat Radiator Brackets
Flat radiator brackets offer an easier maintenance, mounting, and removal process for liquid cooling with more clearance for push-pull configurations.
Our Achievements
17 Awards
Curved Tempered Glass Side Panel
A lightly-tinted tempered glass side panel with two curved edges
offer a wide view of the system build.
Rich Connectivity
Ports & Slots
Rich Connectivity
The advanced I/O panel comes with a 4-Pole headset jack (audio+mic), dedicated mic jack, USB 3.1 (Gen 2) Type-C port, four additional USB 3.0 ports, PWM fan speed button, and an addressable RGB control button.
Design
HIGHLY VERSATILE LAYOUT
The unique frame design supports a conventional, chimney, inverse
layout, or a fully customized layout. The motherboard tray is also
removable for installation outside of the chassis.
Cooling Support
16
radiator slots
Cooling Support
18
fan slots
Alternate Rear Panel
To support exotic layouts with motherboards or graphics card oriented vertically, an alternate panel with rubber grommets is included to allow a pass-through for external cables.
EXTENSIVE CABLE COVER SYSTEM
The 3 included covers can be placed on either the M. Port or on the mid-plate, with the ability to mount SSD storage or a reservoir.
  • 尺寸 高直立式
  • 材質 金屬
  • 水冷支援 - 底部 120mm
  • 水冷支援 - 後方 120mm
  • 電源供應器類型 下置式
  • 防塵濾網 上方
  • 尺寸 (長x寬x高) 639 x 306 x 651mm
  • 風扇支援 - 底部 2x 120/140mm*
  • 預裝風扇 - 後方 1x 140mm, 1200RPM
  • 水冷支援 - 前方 420mm (移除ODD)
  • 預裝風扇 - 前方 2x 140mm, 1200RPM
  • 燈效支援 RGB 控制板
  • 防塵濾網 前方
  • 水冷支援 - 底部 140mm
  • 水冷支援 - 後方 140mm
  • 水冷支援 - 前方 360mm
  • 顏色
  • 5.25" 硬碟架 1
  • 水冷支援 - 底部 240mm
  • 防塵濾網 底部
  • 風扇支援 - 後方 1x 120/140mm
  • 燈效支援 1x RGB 連接
  • 風扇支援 - 上方 3x 120/140mm
  • PCI 擴充槽 8
  • 水冷支援 - 上方 280mm
  • I/O 面板 4x USB 3.0
  • 水冷支援 - 前方 280mm
  • 系列 COSMOS 系列
  • 水冷支援 - 前方 240mm
  • 水冷支援 - 上方 240mm
  • 電源供應器類型 ATX PS2
  • 主機板支援 E-ATX
  • 主機板支援 ATX
  • 水冷支援 - 前方 140mm
  • 水冷支援 - 上方 140mm
  • 水冷支援 - 上方 120mm
  • 主機板支援 Micro ATX
  • 水冷支援 - 前方 120mm
  • 預留安裝空間 - 顯示卡 320mm (安裝3.5"硬碟架)
  • 2.5"/3.5" 硬碟架 (複合式) 4
  • 風扇支援 - 前方 3x 120/140mm
  • 主機板支援 Mini ITX
  • I/O 面板 1x USB 3.1 Gen 2 Type-C
  • 預留安裝空間 - CPU 散熱器 198mm
  • 水冷支援 - 上方 360mm & 420mm (移除 ODD, 最大厚度 70mm)
  • I/O 面板 1x 3.5mm 音訊插槽
  • I/O 面板 1x 3.5mm 麥克風插槽
  • 2.5" 硬碟架 4
  • I/O 面板 風扇轉速控制
  • I/O 面板 RGB 控制開關
  • 預留安裝空間 - 顯示卡 490mm (移除 3.5" 硬碟架)
  • 重量 22.2 kg
  • 材質 曲面鋼化玻璃
  • 產品型號 MCC-C700P-KG5N-S00
